      08-25-2020, 03:28 PM   #1
Tonyc003
Drives: Z4 e86
Need new clutch questions ???????
I may need a new clutch. I currently have a JB racing clutch and flywheel for my 2006 Z4 M coupe. Should I just get a stock clutch back on? This car will also be pass on to my 17year old son.
Please let me know if the stock clutch is good. I never drove with the stock clutch on this car. It already had the JB racing clutch installed.
      08-25-2020, 03:56 PM   #2
1stw0rldpr0blems
Drives: 2006 Z4MC
I just had a stock clutch/flywheel and Autosolutions shifter installed on my car. Prior to this, I was running on the stock clutch/flywheel/shifter with 151k miles on the car.
Big difference. No more chatter from the flywheel, smooth engagement. The pedal feels lighter than it did before. This is also the perfect time to upgrade your shifter assembly if you're still running the stock one.
      08-26-2020, 11:36 AM   #3
wdb
dances with roads
wdb's Avatar
4722
A lot of it is opinion, some of it is how skilled the driver is at using the clutch.
I put a stock clutch and flywheel in my Z4M. I am very easy on clutches and do not heavily track my car.
      08-26-2020, 11:42 AM   #4
Tonyc003
Drives: Z4 e86
Thanks for the responses. I just really want a chatter / Noise free and smooth shifting. What should I except for cost on parts and install???
      08-26-2020, 11:48 AM   #5
wdb
dances with roads
wdb's Avatar
4722
I bought my parts from Pelican or ECS, don't remember exactly. I wish I had used Rock Auto though because they had the exact same parts for much less. I did the work myself.
      09-11-2020, 11:10 PM   #6
T-Bears
T-Bears's Avatar
Drives: E85 2.5i
Price for a clutch job varies with shops, but the labor for your Z4M should be around $1500 + parts or no more than $2200. To give you a baseline my old Boxster was about $2200 OTD and my old 911 was about $3400 OTD.
Clutch replacement is easy it can be done in 10hrs or over a weekend depending on experience. You can save a lot on labor if you have the time and equipment.
