      01-18-2021, 03:53 PM   #1
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
Göke FIA GT4 Group Buy
If any one is interested I will be placing another order for parts being shipped to the US. Depending on the amount production is 60 to 90 days and shipping is 30 to 45 days. Prices below do not include shipping, once orders are received 50% will be due and 50% once it leaves Germany. The more that purchase the cheaper I can get the shipping to the US.
Use can also look here and DM me with any questions. https://sxmotorsports.com/z4-perform...ckages/z4m-gt4
There are 3 types GT which is normal body dimensions, GT4 which is 40mm wider on each corner and GTR which is similar to the Flossman
Part Description Material OEM Part Weight Part Weight Price
Front Bumper with Splitter Carbon Fiber 11.90lbs est. 12.60lbs $2,600.00
Front Bumper Hardware Aluminum NA NA $175.00
Front Fenders right & left (set) Carbon Fiber 9.35lbs each est. 3.90lbs each $2,200.00
Side Rocker Panels right & left (set) Carbon Fiber 4.30lbs each est. 1.30lbs each $600.00
Rear Fenders right & left (set) Carbon Fiber 5.80lbs each est. 3.60lbs each $2,100.00
Doors right & left (set) Carbon Fiber 27.90lbs each est. 7.20lbs each $3,800.00
Hood Carbon Fiber 24.20lbs est. 10.12lbs $2,150.00
Roof Carbon Fiber 14.87lbs est. 8.10lbs $1,095.00
Diffuser Carbon Fiber NA est. 2.40lbs $1,825.00
Rear Bumper OEM 11.90lbs est 5.40lbs $1,600.00
Trunk Lid Carbon Fiber 33.20lbs* est. 11.20lbs* $1,950.00
Wing Carbon Fiber NA est. 4.15lbs $2,200.00
GT4 Carbon Dash Carbon Fiber 11.50lbs est 4.20lbs $1,950.00
Carbon Air Box for Z4M Carbon Fiber $2,400.00
      02-08-2021, 05:21 PM   #2
F360C
Drives: E86 S54
Can the 40mm wider front and rear fenders be used with stock front and rear bumpers?
07 Z4 M Coupe AW/IR
      02-10-2021, 04:40 PM   #3
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
It uses the stock rear but you have to replace the front. He does make a standard size front and you can use the wider rear fenders
      04-08-2021, 07:35 PM   #4
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
I am putting together an order this week if anyone is interested.
