12-19-2020, 08:07 AM | #2 |
Rep 2,704
The OEM antenna is a pain to remove, especially if the threaded parts are corroded.
I simply cut done my stock antenna. Reception for me was not affected.
12-19-2020, 10:12 AM | #3 |
Retired
96
Rep 174
I have used this one for years and it works very well
https://www.ecstuning.com/b-genuine-...m/65202296761/ Lots of others are available on Amazon (Never cut your antenna, it has a measured length of coil for optimal reception) |
12-19-2020, 11:50 AM | #4 |
Rep 160
https://www.cravenspeed.com/stubby-j...w-z3-z4-coupe/
I've run these Stubby Jr's on my last 3 cars and they look great and have never affected reception. |
12-20-2020, 02:22 PM | #5 |
Rep 63
I've had this Cravenspeed stub on my 2003 Roadster for 3 years without issue. Easy install and no reception issues.
https://www.cravenspeed.com/the-orig...w-z3-z4-coupe/ |
Dbaliko36.50 |
12-24-2020, 03:33 PM | #7 |
Rep 18,727
Spray some penetrating oil under the old antenna lip to get it on the mounting screw threads. I broke my antenna off in the mount and had to drill it out and re-tap the mount.
