06-09-2020, 09:40 PM | #1 |
Rep 6
Z4 Masterminds wanted: Engine cranks but will not start- tried everything! Help!
SOLVED!!!!
(This is my first post so apologize if this is in the wrong place, or if this problem has been covered -- I have searched and searched with no luck – feel free to move) Details: 2008 e85 Z4 with N52 (MSV70). Has 113,000 miles. Model is a 3.0i, but did a 3-stage conversion with Bimmerlabs 3.0si tune. RSA Delete and Tune with 3 stage manifold were done two weeks ago – once complete car drove just fine (Better!) until this weekend. Problem: Engine cranks but will not start. The problem began a couple days ago when it didn't start (still cranked), but then start after waiting 10 minutes. Happened again Sunday, engine wouldn’t start (cranks) but then randomly started one time. Over the past 24 hours will not start (still cranks). Ruled out:
CODES Thrown: All ECU Related:
If I clear them they all come right back. Honestly I am really nervous if this is coding related -- Im a noob and flashing the Bimmerlabs tune and poking around in INPA is my skill set is at this point. Help?! __________________________________________________ ______________ SOLVED: The issue was the DME Relay was broken. The problem is the Z4 2006 - 2008 (also the X3) have an IMV that houses the DME Relay on a circuit board. Its very unusual for BMW and found OUTSIDE of the ECU/DME engine compartment. Here is a picture of the DME Relay, ECU fuse box with integrated circuit board. Picked one up for $40 on eBay and car fired right up! Last edited by ncmish; 06-15-2020 at 08:49 PM.. Reason: Solved! |
06-10-2020, 06:27 AM | #2 |
Rep 484
Ironically, I’m going through the same thing at the moment with my M Coupe track car. After much analysis with Randy at Epic, we have come to the conclusion that the ecu is faulty and/or the immobilizer is somehow active behind the scenes. Also confirmed by a gentleman I spoke to at Precision ECU. I am awaiting a reflashed replacement ecu.
06-10-2020, 09:02 AM | #3 | |
Rep 6
Also -- how sweet would it be to have an M Coupe track car! |
06-10-2020, 12:18 PM | #4 |
Rep 506
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
Did you check the throttle actuator? Check to make sure you are getting power there at both end points.
06-10-2020, 01:04 PM | #5 |
Rep 6
06-10-2020, 01:13 PM | #6 |
Rep 506
If the car is turning over, but not starting especially after doing the upgrades you just have done there could be something preventing fuel to pass and fire the engine. I ran into a similar problem when I installed Dinan throttle bodies. Pull the air box off and check to see if your throttle bodies are getting power. There is an auto turn off function that cuts power to the throttle body. Either way take a meter and test to make sure you are getting power and then go from there.
06-15-2020, 08:51 PM | #7 |
Rep 6
Here is a picture of the DME Relay, ECU fuse box with integrated circuit board. Picked one up for $40 on eBay and car fired right up! |
06-19-2020, 03:18 PM | #8 | |
Rep 12,565
filtercoffee106.00 |
