07-02-2019, 06:21 PM | #1 |
Rep 12,567
Any Review of Brey Krause Seat Mounts?
Anyone here have direct experience with BK seat mounts in the Z4? I used Macht Schnell before and while not perfect, I was able to get everything to work with my old Recaros. I just had to enlarge some of the holes but nothing too bad.
I’ve read reviews from e46 m3 users but we all know how anything that should be compatible in “theory” is never 100% and for something like this, any little variance can make all the difference between a perfect install and a nightmare job lol. Last edited by 3002 tii; 07-02-2019 at 11:00 PM.. |
07-15-2019, 12:36 AM | #3 |
Rep 342
Just finished getting my Brey Krause seat mounts w harness clips and original sliders installed and supporting a Sparco QRT Performance seat. I wired in a $10 aftermarket E30 switch and have power slider working. No Airbag lights, didn't blow off any fingers.
Here is my review: @!#%# $@$#@# @$#@!~! @##%~!~~~~!!!! )(&*@#$^&*@!@~!~!!!!! WTF?!! |
3002 tii2293.00 |
07-15-2019, 02:12 PM | #4 |
Rep 12,567
Got pics??
07-15-2019, 08:12 PM | #5 |
Rep 342
Here is the door clearance, it's about 1mm, though I had to use a spacer to bump it over.
Untitled Here is how the mounting looks, showing the aftermarket E30 switch. Sparco QRT seat installed in BMW Z4M Roadster This is how it looks in the car. Good match for the stock seat imo. Sparco QRT seat installed in BMW Z4M Roadster Sparco QRT seat installed in BMW Z4M Roadster Initial impressions of the seat are very favourable. Very comfortable, nice solid feeling. The exterior bum of the seat is wide and restricts adjustment positioning. I need to mess with it, but in this configuration - with the stock sliders - I can't drop the back of the seat down beyond the first mounting position (highest). It bumps into the stock rail mount. From my initial driving impressions, I think I might want to drop the rear down 1 or 2 holes, so I will need to experiment with that. The stock seat belt receptacle location is not a problem, you can see that the seat does not interfere with it in a way that would change the seat belt position. I knew I would end up doing this at least twice to get the seating position right, as well as install the harness. I will make a better write up second time around. Cheers, Eamonn |
07-16-2019, 02:26 AM | #6 | |
Rep 431
07-16-2019, 11:00 AM | #7 | |
Rep 342
I will say that part way through the installation, I was wishing for the simplicity of just mounting it to the floor hehe. Only street driven thus far, will have it on a track in a couple weeks, will report back afterwards. Cheers, Eamonn |
01-13-2020, 02:58 PM | #8 |
E86 M Coupe
265
Rep 405
I installed some brey krause mounts for the factory slider rails. Would recommend! Very simple and solid mounts!
01-13-2020, 05:23 PM | #9 |
Rep 12,567
What seats did you go with? Got pics or link to your install?
01-13-2020, 08:50 PM | #10 |
E86 M Coupe
265
Rep 405
I have the Recaro SPG XL and used these exact instructions (http://qnuwm.rpstd.servertrust.com/v...ions/R9246.pdf) |
3002 tii2293.00 |
01-13-2020, 09:50 PM | #11 | |
Rep 12,567
01-14-2020, 12:51 AM | #12 |
E86 M Coupe
265
Rep 405
Yeah seat is centered to the steering wheel, got about an inch of clearance on the door panel also
