01-22-2021, 05:32 PM | #1 |
Rep 12
I'm 16 and saved up for a used 2003 z4 2.5i and upon getting it home and doing more research found out the previous owner had dropped a 3.0 from a 2002 330i. I drove it once and white smoke blew from the tailpipe and the car died going up my drive way. after talking to a buddy of mine that runs a dealership he said that it was a blown head gasket and although it would be hard and slow if i was meticulous enough about it i would be able to get it done knowing nothing about engines. i don't have a dad or any adult to help me and ik i'm taking a big undertaking and risk here but i'm passionate about cars and want to get this one back on the road. right now i'm stuck on what to do next, and what to do about the white sludge, do i clean it? hose it off? ignore it? i'm sorry if this has been answered somewhere else but to be honest i'm extremely lost.
01-22-2021, 05:45 PM | #2 |
Rep 2,782
Your best bet is to buy a used $800 M54 engine and swap it in. A 3 liter engine will require some different parts but nothing exotic... namely a MAF sensor and ECU tune. You can install an OEM 3.0 tune with WinKFP, but it will only function properly with the 3.0 MAF.
A head gasket change will require skills and tools you likely don't have yet, and not doing it right will result in engine failure. Even if you somehow manage to change the head gasket properly, it doesn't address the root cause of the head gasket failure. A head gasket failure is often a symptom of a warped head, usually due to the engine overheating.
wdb4718.00 |
01-22-2021, 05:54 PM | #3 |
Rep 2,704
Wow, so many things wrong in those pics.
Wish I was closer, I would help you fix it. I think that engine was abused. Headers, catch can, unplugged O2 sensors, likely vacuum leaks from the taped up intake pipe. Did you break the nose off the coil taking it out? Before thinking the worst and a blown head gasket, put this into google. "BMW M54 White Sludge" First 3 hits are videos to diagnose, blown HG and causes of white sludge. Report back when you get a definitive answer to whether it's the HG. Good luck.
FinniganG1.50 |
01-22-2021, 06:04 PM | #4 | |
Rep 12
01-22-2021, 06:06 PM | #5 | |
Rep 12
oh and the coil was already broke |
01-22-2021, 06:07 PM | #6 |
Rep 685
I'm actually doing one right now on my RallyX car...mind you it's not the same kind of car or engine. Really the Z4 engines aren't too bad to work on and even enjoyable. Like your friend said it just takes time and being thorough with documenting everything you remove and being extremely clean. Example gasket surfaces being perfect clean and smooth, miss that step and you'll be doing it again.
Like the previous poster said the biggest issue is that it may have warped. I was lucky with my car and I didn't have that issue but it also didn't sound as bad as yours. It's not hard to check for. All you would need is a $40 machinest straight edge and a set of feeler gauges. That would show you if it's warped. If they aren't then you would just need a engine gasket kit and what ever other parts you need. I would break it down first to see if it's warp and if it is then go the used engine route. I would stay with the 3.0i. I've had both and would rather have the 3 over the 2.5. Best of luck to you! Just try not to let it get you down, use it for gaining experience that can save you big bucks in the future. |
01-22-2021, 06:18 PM | #7 |
Rep 12
And what do i do about the white sludge? i assume i'm not supposed to just ignore it but it's in every hose do i take it all apart and clean every single one out?
01-22-2021, 08:02 PM | #8 |
Rep 685
After looking at the pics again I'm worried about this car in general. It wasn't a flood car right? I'm surprised how rust covered the coils are so those will need replaced too most likely, especially if they came into contact with the coolant. Yeah, I would just clean all the lines out. Well I guess you could always try a bottle of the dreaded head gasket sealer...has a high risk of causing clogs, plus the gasket may be too far gone.
01-22-2021, 09:20 PM | #9 | |
Rep 12
01-22-2021, 09:32 PM | #10 |
Rep 12
another thing i haven't mentioned is that it looks like they were on a rush or something to put together this engine. where there would be 4 booths they only put two, and where there would be 6 there's three, ie. there's just enough screw to keep it together. it's confusing why they would just rush through something like this, again though the rest of the cars perfect, the only problem in seeing is with this engine
01-23-2021, 11:45 AM | #11 |
Rep 685
Maybe they had a more built engine and just threw that junk one in to be able to sell it. Who knows. Is the trans an auto? Also did they convert to hydro steering or is it the normal electric steering. Just curious as they've done a lot of other things. Just fyi the steering will drive you crazy in hot weather with out a "fix" done. My 03 drove me insane. One of the reasons I bought an 08 coupe.
01-23-2021, 01:51 PM | #12 | ||
Rep 2,782
01-23-2021, 02:03 PM | #13 | |
Rep 12
01-23-2021, 02:03 PM | #14 |
Rep 561
01-23-2021, 02:07 PM | #15 |
Rep 12
i am just going off what i was told but the seller but as i'm realizing i shouldn't completely trust
01-23-2021, 02:37 PM | #16 |
Rep 685
02-10-2021, 10:39 PM | #17 |
Rep 98
Drives: E85 2.5i
Garage List 2008 Kawasaki Ninja [0.00]
2001 SLK230 AMG Spo ... [0.00] 01 Yamaha R1 Crotch ... [0.00] 2004 BMW Z4 [9.00] 94 Honda Fireblade ... [0.00] |
If I were you get to know your car before making any big decisions. Find out what you are working with. Ask yourself these questions.
1. Do you have factory ECU that came with your car or was it swapped out? 2. How is your engine harness is it butchered or still intact? 3. Do I want to bring the car back to OEM specs with a 2.5 engine or just work with the 3.0? 4. Will I be able to have the time and budget for this project? Once you have an idea or a game plan then everything will be easier. We know your head gasket blew. You could remove the head have it resurfaced and rebuilt but would that be enough? Are you just trying to get this car on the road or properly fix it? Is this just a project car? Take your time make a parts list, buy a set of tools, and a repair manual. Let us know if you needs pictures for reference if you can't find one online or just any random questions. I have a lot of tools from sockets to micrometer if only you were closer to me. Last edited by T-Bears; 02-10-2021 at 10:49 PM.. |
02-11-2021, 10:25 PM | #18 | |
Rep 12
wdb4718.00 |
03-03-2021, 03:47 AM | #20 |
Rep 98
Drives: E85 2.5i
Cool, I have driven a 3.0 once and it had a stronger top end performance compared to my 2.5i. That extra 500cc really made a difference. I'm thinking of getting a VF Engineering blower in the future but first will probably have my transmission rebuilt.
