Go Back   ZPOST > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Photography/Videography
      10-28-2009, 05:38 PM   #1
anthony @ eas
anthony @ eas's Avatar
Drives: R56 Cooper S
My first attempt at rig rolling shots.
...and it looks like I'm in need of a lot of help.
Here are the final products:
Here is an original. I had to use WAY to much PS to make it look halfway decent.
I only had a short pole so I couldn't get the whole car in the frame. I'll go to Home Depot to get a longer one.
Some questions:
1. Is it possible to do this in bright daylight without a filter? I couldn't get any long exposure times even with f22 and ISO100. You must have to be driving ad 50mph+ to get any motion.
2. Is it better to push the car or drive it? I found the car to be sharper when pushed (the two I posted are being pushed at 1mph max), but the motion blur obviously wasn't as apparent.
So if you guys have any tips, tricks or criticisms let me know. Thanks guys.
      10-28-2009, 05:46 PM   #2
radiantm3
Apex Everything!
radiantm3's Avatar
Drives: 2007 Honda S2000, 2017 GT350
2011 E92 M3  [9.35]
2014 BMW i3  [10.00]
Definitely need a dark ND filter in the day time. I like to push the car for at least 10-15 seconds. No need to drive the car.
Be careful pushing the car too fast especially if the ground isn't completely smooth. My camera started bouncing a bit because I was pushing the car too fast and ended up putting a small dent in my roof. I'm sure the hood is a bit stronger though.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com
      10-28-2009, 08:14 PM   #3
BillLee
BillLee's Avatar
Drives: E92 M3
09 E92 M3  [9.00]
what lens are you using?
      10-29-2009, 01:06 AM   #4
1013mm
aka 1013MM
1013mm's Avatar
Hong Kong
1253
Drives: pokingly flush
2009 135i  [8.26]
get a wider lens!!!!
      10-29-2009, 11:19 AM   #5
anthony @ eas
I'm using an 18mm lens. It should be wide enough, but the pole I was using was only 4 feet long.
      10-29-2009, 07:11 PM   #6
AllydNYC
Loading...
AllydNYC's Avatar
No_Country
342
Drives: 91' E30 318is
1991 BMW 318is  [0.00]
Um on a side note, the second picture looks fucking awsome!
      10-29-2009, 11:53 PM   #7
BillLee
BillLee's Avatar
Drives: E92 M3
09 E92 M3  [9.00]
have you read this article?
http://www.rigshots.com.au/howto1.ht..._shutter_speed
      10-30-2009, 11:15 AM   #8
anthony @ eas
Originally Posted by Bryan0102 View Post
what was your rig setup? im interested in this but dont want to spend too much cash.,,
I got everything from Amazon based on this list of items:
http://www.diyphotography.net/take-c...alized-car-rig
Originally Posted by BillLee View Post
I haven't seen that one yet- thanks!
      11-01-2009, 12:03 PM   #9
Teshi
Drives: Blue/Usually full of camera ge
Filters are the only way for daylight. Even at ISO50 @ f32, I have problems. A 10 stop ND filter would be awesome but need to be careful of vignetting on a UWA.
I would recommend pushing the car with the gearbox in neutral. Less vibration from the engine and only vibration should be from the road.
This was the original motion shot
Here it is finally edited
I had to use a composite of the stationary shot and the motion shot to bring back sharpness. If I had pushed, would have required WAY less editing.
      11-02-2009, 11:56 AM   #10
JustXtreme
JustXtreme's Avatar
21
Drives: White 128i
whats funny is on the 2nd shot you did a great job on the ps but you didn't clone out the reflection of the car in the bumper.
      11-02-2009, 01:28 PM   #11
anthony @ eas
OK, looks like I need a filter. Something like this would probably work:
https://www.adorama.com/HY58PF.html
      11-02-2009, 01:41 PM   #12
Teshi
If you get that, let me know how you get it. I would still rather just go for a 10 stop ND filter instead. Less chance of filter rotation and changing the exposure.
      11-02-2009, 02:06 PM   #13
anthony @ eas
Could you post a link to one of those?
      11-02-2009, 02:11 PM   #14
Teshi
Something along these lines.
https://www.adorama.com/BW62ND8XDP.html
      11-02-2009, 03:42 PM   #15
anthony @ eas
^^ Cool- I might just go with the adjustable polarizing one for the versatility for now. If I do, I'll definitely post the results/feedback here.
Thanks for everyone's help guys!
