      07-11-2011, 09:56 PM   #1
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
Carbon Fiber (CF) Z4 Coupe roofs-Feeler participants
Hello Z4 coupe fans.
This is simply a thread to help me establish the order line for the upcoming CF roofs I'll be building soon.
For those unaware......I've just finished the top-skin Resin Infusion mold and I'm working on the substructure mold currently. ( As well as a high heat male mold for the clear moon-roof-kit).
In the meantime.....who is solid on getting in line ? These will be built one at a time in this process >>
1)-Vacuum Assist Resin Transfer Carbon Fiber.-(no air voids)
..........Platinum Silicon custom Vacuum bag.
----2x2 Twill-----or CF Plain weave or Texalium Silver 2x2 Twill....2x2 Twill w/V-weave......or 2x2 Twill Hybrid /Kevlar colors (example=red,blue,white,green),.....Added fee applies for the last 3 custom orders.
2)-Post cured at 125*-( Insures final cure and strength).(No warp/skew)
3)-Substructure also made from CF.
4)- Direct full roof replacement with directions and Stainless hardware kit.
5)- Standard finish will be UV stabilized automotive urethane clear- Wet-sanded and polished).
6)- Boxed for shipping with foam corners and insured.
7)- Cost=first 10 units will be $1,450.00 + Shipping.
I'll convert this to a group buy thread after it takes shape and I have pictures of mine mounted etc.
So lets get this party started, who wants in ??
SAMPLE>>
1)-John DoeZ- 2x2 Twill -Silver Texalium.
This list of buyers last updated 1-24-13.
1)-Dark Schnitzer---------2x2 Twill-V-weave.
2)-inTgr8r----------------2x2 Twill-standard-weave
3)-VinnieAces------------ 2x2 Twill-V-weave (Maybe)
4)-cfine88----------------2x2 Twill -standard weave
5)-Finnegan--------------2x2 Twill - standard weave ?
6)-NEKO ---------------- 2x2 Twill-V-Weave
7)-mexicobmw------------1x1 Plain weave
8)-habitat412-------------1x1 Plain weave
9)-doktore----------------2x2 Twill V.
10)-RobMCoupe-----------2x2 Twill
11)- Jumbosock-----------2x2 Twill-standard-weave
12)-GCDC-----------------2x2 Twill - standard weave
13)-Urluz3n---------------2x2 Twill- standard weave
14-2point0---------------2x2 Twill-V-weave
      07-12-2011, 11:27 AM   #2
MIKe86
Drives: 90 332is
Good stuff man, love to see all this coming through. Curious what the hybrid with the white looks like.. Any pics of something similar?
Also, are these roofs smooth tops like the other cf ones or are the M rooflines molded in like oem?
      07-12-2011, 11:56 AM   #3
Twisted Six
Drives: Z4si-coupe
Mine still have the Z4 coupe roof lines-(OEM). Take a look at the mold pix. You can still see them there.
The White CF/Kevlar hybrid cloth looks like >>
All of the CF/Kevlar hybrid colors share blk. in the opposite tow. So Red is red/blk.....blue/blk. etc.
The 2x2 Twill describes the weave pattern and number of tow crisscrosses.
      07-12-2011, 12:37 PM   #4
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Would it be possible to post a photo of the CF Plain weave?
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
      07-12-2011, 12:55 PM   #5
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
This was probably answered in the other long thread (apologies if that is the case): what kind of weight savings can be expected?
Now, that's now accounting for the coolness factor which looks like it's been hit right out of the park!
      07-12-2011, 01:04 PM   #6
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
sub'd!!!!!!
Not in the market as of right now, but I most likely will be in a year or so... Looking forward to all the results!
      07-12-2011, 01:19 PM   #7
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
OK maybe I'm missing it, but is this a straight CF replacement
or
Is this the removable CF top?
Also;
Is the CF laid up from one piece of cloth?
Some of the earlier CF tops (TC Kline) were multi pieced together.
      07-12-2011, 01:45 PM   #8
Twisted Six
Drives: Z4si-coupe
Plain weave was used previously for OEM BMW parts and is most common....but not ALWAYS the money shot,so to speak.
However...if you already have Plain Weave CF on your car...it usually looks best to continue with that theme or weave.
Plain Weave >>
2x2 Twill looks like >>
RED 2x2 Twill >>
BLUE 2x2 Twill >>
SILVER Texalium >>
      07-12-2011, 01:46 PM   #9
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
It's for the coupe, so I'm assuming it's on glued/ screwed on just like the regular coupe roof.
      07-12-2011, 01:54 PM   #10
Twisted Six
Drives: Z4si-coupe
or
I'll be making the CF roof component first. Straight replacement ,as you put it. The removable kit will follow separately. If one wishes to NOT glue their roof back on in wishing to utilize the removal kit later...I have a seal in development for this.
Also;
These will have ZERO seams/parting lines etc. ONE PIECE cloth installations.NO cloth interruptions in other words.
Generally, Resin Infused CF parts weigh in about 2/3rds the weight of their metal counterparts.An aluminum part about 1/2....but you gain MUCH more strength and dent avoidance with CF.
      07-12-2011, 01:57 PM   #11
Twisted Six
Drives: Z4si-coupe
The OEM roofs are bolted on at 4 points with additional urethane sealant all the way around.
I'm developing a Platinum soft silicone seal to replace the messy issue with the sealants.
This way...if someone buys my products....they can easily remove the tops to re-sell or take off at anytime without the previous hassles.
Just the four bolts essentially.
      07-12-2011, 02:16 PM   #12
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Absolutely fantastic work on this!!!!
I would love to jump in now, but my budget is already waaaay past the CFO approval point.
Definitely interested down the line though.
      07-12-2011, 02:19 PM   #13
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I hope you coupe bastids come through, Dark has been working hard on these parts because you're the ones who requested it, so now its time to put your money where your mouth is
      07-12-2011, 02:25 PM   #14
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Ahhh screw it!
I'm in schit now anyway.
2)-inTgr8r-2x2 Twill-weave
      07-12-2011, 02:42 PM   #15
dorifto88
Drives: 88 Nissan Pathfinder
interested as well, but would like to see installed images, along with actual weight comparisons of oem pieces and your pieces.
      07-12-2011, 02:49 PM   #16
Twisted Six
Drives: Z4si-coupe
Ahhh screw it!
^this
Great, Thanks !
1)-Dark Schnitzer-2x2 Twill-V-weave.
3)-
4)-
5)-
6)-
7)-
8)-
9)-
10)-
      07-12-2011, 02:56 PM   #17
Twisted Six
Drives: Z4si-coupe
I weighed the metal roof last night.But have not placed it to memory. I'll post the comparo up once I have assembled the two halves and can photograph the parts while sitting on the scale.
How's that ?
      07-12-2011, 02:59 PM   #18
dorifto88
sounds dope ! i didnt intend to sound like a jackass, sorry if i came off as such =/
      07-12-2011, 03:33 PM   #19
Twisted Six
Drives: Z4si-coupe
Nope....ALL good questions in my book !
      07-12-2011, 07:13 PM   #20
CJW2OO4
CJW2OO4's Avatar
if I was not poor I would be all over this.... If zposters want to I can set up a paypal account for donations......
      07-12-2011, 07:55 PM   #21
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Sweetness!! Since there are four bolts at each corner applying pressure why not just recommend a self adhesive weather seal that you can buy a roll of at The Home Depot?
      07-12-2011, 08:08 PM   #22
gcochard
Drives: 2011.5 E90 M3
2011 BMW M3  [0.00]
cf hardtop for the roadsters too?
