      04-29-2019, 08:50 AM   #45
Lorcan
The artist formerly known as AC Schnitzer UK
Lorcan's Avatar
3609
Drives: The Yellow Peril
Originally Posted by Brake_Late View Post
Correction: I meant direct /
Are you SURE it's a twin turbo ?? I dont think so
You can see both turbos in this one picture.
      04-29-2019, 09:29 AM   #46
Brake_Late
Brake_Late's Avatar
Norway
1938
Drives: 2015 F82 M4 FIREORANGE2
I see two motors, one old and one new -
each with a single turbo. But only One per engine.
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams,
CarbonStrucktureAnthracite, CF_Everything
BMWPhotoVin, 01of01, GTS DCT, EPS, MDM,
CS EDC,Analog Dip ,GTS parts.
Euro Vin e30 M3, FIA cage / 14.7 p / w ratio.
Euro E30 touring G30 MSport i3s LBB X5M
3.2carrera
https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA
      04-29-2019, 09:42 AM   #47
Lorcan
Lorcan's Avatar
3609
Doh! I thought it was showing both sides of the same motor - ignore!
Brake_Late1937.50
      05-03-2019, 10:24 AM   #48
OkieSnuffBox
Drives: '13 135i
Originally Posted by Bobby P View Post
Incredible, how they are able to produce over 600 HP with a 4 cyl. engine.
Why? They used a 1.5L I4 in the 80s for Formula 1 that was rumored to hit 1500hp in qualifying mode.
That was with 80s tech on head design, turbo's, fuel, computers, etc.
Current 1.6L V6 F1 engines are around 900hp with severe fuel-flow limits, which in turn, naturally restricts the RPMs they can run. They typically shift around 11k, but are designed for 16-18k. That ignores the V8s that were turning 22k before they restricted them to 20k.
Brake_Late1937.50
      05-03-2019, 10:27 AM   #49
Brake_Late
Brake_Late's Avatar
Norway
1938
3.2carrera
Bobby P88.50
      05-03-2019, 10:53 AM   #50
Bobby P
Drives: M240i/VW MK7.5 GTI
Okay, good to know. Impressive.
      05-05-2019, 10:05 AM   #51
Brake_Late
Brake_Late's Avatar
Norway
1938
Already winning ⚡️⚡️⚡️ #turbopower #bmwp48
3.2carrera
      05-10-2019, 09:56 PM   #52
billnchristy
Drives: 2022 M440xi GC
Originally Posted by yco View Post
2.5 bar on a petrol engine sounds great..
Stock m35i engine is pushing 1.55 bar. It isn’t inconceivable to hit 2.
Brake_Late1937.50
      06-23-2019, 10:27 AM   #53
Brake_Late
Brake_Late's Avatar
Norway
1938
3.2carrera
