      02-10-2019, 10:57 AM   #1
mex777
mex777's Avatar
Romania
Drives: BMW Z4 E85 3.0i
Hello!
I am trying to code CVM module using NCS Expert to retrofit the hardtop and I get an error. What I'm trying to do is to activate the function where the ECU detects the hardtop. Basically disable the buttons (Open/Close soft top) when the hardtop is on the car. NCS Expert reads CVM but can't write the new values. Please help!
      02-11-2019, 01:45 PM   #2
mex777
mex777's Avatar
Romania
.TRC file looks like this:
I change it to aktiv and save the file as .MAN and then when I try to code it I get the error from the beginning. I can GM5 but not CVM.
Is there another option or special settings which needs to be changed together with HARDTOP DETECTION?
The error log file looks like this:
      02-11-2019, 09:10 PM   #3
JAS1169
Drives: BMW 2003 Z4
Give this Forum a try:
www.**************/
I think that Forum goes into BMW computer info.
However, if all else fails simply trace the up/down buttons back to the fuse box and simply pull them when the hard top is on and re-install when you go back to the soft-top.
      02-12-2019, 10:38 AM   #4
JAS1169
Drives: BMW 2003 Z4
for reasons unknown this site will not allow you to post links to other sites.
maybe it will work this way. Search for a site called bmwcode.com
      02-13-2019, 09:02 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
In general you can post links to other sites.
For reasons unknown, zpost has blacklisted a few.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
