      06-10-2019, 08:44 PM   #1
Lucky1
Drives: '08 128i Coupe SGM 6MT
Any idea what's leaking under here? Its not from the struts. Driver side. Leaking from right under the corner of the bumper. Going to put a plastic container underneath to collect whatever is leaking to see the colouration.
      06-10-2019, 08:48 PM   #2
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
If you have head light washers it could be those. I have that problem. Could be coolant too but that usually goes towards the middle.
      06-10-2019, 08:54 PM   #3
Lucky1
Photo added.
      06-10-2019, 09:03 PM   #4
Our03z4
Still thinking head light washers.
kaybat125.50
      06-10-2019, 09:05 PM   #5
Lucky1
No headlight washers but my washer fluid reservoir was bone dry when I pulled it out of storage. Pretty sure I filled it up to a higher level than it is now and the colouration is the same orangey colour of my washer fluid that I used.
      06-10-2019, 09:08 PM   #6
Our03z4
You're positive you dont have them? You have the cap on the bumper that pops up. Not sure if the M came that way with out them or not.
kaybat125.50
      06-10-2019, 09:13 PM   #7
Lucky1
Well I'll be damned. You learn something new everyday.
      06-10-2019, 09:16 PM   #8
Our03z4
Haha. Hey man I didn't know my coupe had the option until I accidentally sprayed them. Freaked me out.
      06-10-2019, 09:32 PM   #9
Lucky1
Thanks, good call. Will report back when I figured out precisely where the leak is coming from. At least washer fluid is the least important car fluid especially on a convertible only used on sunny days with no bugs around
      06-11-2019, 06:55 AM   #10
Huz-Z
Huz-Z's Avatar
OR!
Maybe the cat peed on it.
Huz-Z
      06-11-2019, 10:20 AM   #11
Lucky1
Originally Posted by Huz-Z View Post
OR!
Sure if my cat's pee is orange
Topped up the washer fluid last night and here's how much leaked overnight.
      06-11-2019, 11:08 AM   #12
Huz-Z
Huz-Z's Avatar
Yeah, I had to hide the tropical-flavored rum coolers from my cat too.
Huz-Z
      06-11-2019, 02:04 PM   #13
StickMon
StickMon's Avatar
Drives: 2006 MR
Remove the bumper cover.
Remove the headlight washers and hoses up to and including the tee.
Plug the remaining hose.
Take the caps off the washers and attach them to the bumper cover.
Problem solved.
      06-11-2019, 02:53 PM   #14
Huz-Z
Huz-Z's Avatar
Why not look for the leak and repair it so not to lose the headlight washer functionality?
      06-11-2019, 03:24 PM   #15
StickMon
StickMon's Avatar
Drives: 2006 MR
There's headlight washer functionality?
At least down here in SoCal, the only function they serve is to break.
      06-11-2019, 09:18 PM   #16
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
And dirty up the entire car
      06-12-2019, 06:45 AM   #17
Huz-Z
Huz-Z's Avatar
That's weird. My E70 X5 has headlight washers that work just fine, even after multiple Canadian winters. My Z4 does not however so I can't comment on them. But maybe the washer design on the Z4 is different and more problem prone somehow.
Huz-Z
      06-12-2019, 11:02 AM   #18
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
The headlight washer/windshield washer system in this car is pointless in my opinion. I removed the whole system completely
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
kaybat125.50
      06-12-2019, 03:20 PM   #19
unluky
unluky's Avatar
7528
I never understood this. It just sprays fluid on them right? With no wiping or anything? Don' see how that would clean anything except maybe dust. And I think it would make a freaking mess everywhere.
Never thought they would work for crap.
      06-12-2019, 03:58 PM   #20
GuidoK
#buildnotbought
GuidoK's Avatar
10852
Drives: Z4 3.0i ESS TS2+
Thats exactly their function; remove dust/sand/mud (or even snow).
As far as testing their function (in development/typeconformitychecks), there's even an official norm that specifies a certain mixture based on birchsawdust that has to be applied to the lights that the washerjets have to get off for a certain percentage/area etc etc.
The jets are required when headlights go over a certain emitted output of light (lumen).
Wiping systems on headlights haven't been used since mid 90's or so as they smear the dirt doing more harm than good.
A washerjet doesn't have this effect and are therefore safer.
StickMon636.00
wdb4721.50
      06-13-2019, 05:49 AM   #21
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Kinda like dating a girl, until you find out she has a set of doo-dads between her legs?
      06-13-2019, 08:10 AM   #22
unluky
unluky's Avatar
7528
All I can imagine is shooting washer fluid on my bug covered windshield - which only seems to make it worse!
