05-13-2020, 03:19 PM | #925 |
Rep 1,913
Drives: Here and There
What are you guys doing for irrigation? I wish I had a built-in, but I'm not going to drop the coin on a place we only intend on being in for another couple years or so. We've got a tiny bit over half an acre that's long and relatively narrow. Closest spigot I have to the grass closest to the street requires me to have ~150ft of hose and I'm just not coming up with a decent solution. I have a total of three spigots (one on each side of the house except the front) and I really can't run more than one of them at a time without significantly reducing the water output of both.
What's a good way to measure water pressure? What should it be? I don't want to have exterior pressure to take care of the yard in a good spot and find that I'm blowing a faucet off inside. Once pressure is figured out, what's some good hardware? I've seen some YouTube guys taking in-ground sprinkler heads and modifying them to be put on spikes. I really would like to be able to do multiple in series if possible. I'm currently putting one at the end of my hose length and it can take me over two hours to water the whole yards. We're in a bit of a drought right now with no rain on the horizon. I'm killing myself trying to keep the yard from dying of thirst. |
05-13-2020, 03:27 PM | #926 | |
Rep 83
My yard is fully irrigated, but use these for beds. Maybe something similiar? https://www.gardeners.com/buy/snip-n...m/8589718.html |
spazzyfry1234340.50 |
05-13-2020, 03:29 PM | #927 |
Rep 4,821
I have irrigation and put a well in for the irrigation. City water for the house.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
05-13-2020, 03:43 PM | #928 |
Rep 83
05-13-2020, 03:45 PM | #929 |
Rep 4,821
I out the well in because I was spending a lot on city water for irrigation. I think it was $1,200 back in 2002. Money well spent as I think it has paid for it self a few times over.
tim99ws6110.00 |
05-15-2020, 08:37 AM | #930 |
Rep 14,522
grass is doing well after that RGS/HUMIC12 app.
tulips are doing great but pretty soon will be coming to their end of their life cyle Went to our local nursery and i picked up a full load of Super Tunias from Proven Winners! also picked up a couple varieties of Salvias
Rmtt8209.00 |
05-15-2020, 12:17 PM | #931 |
"Salud"
13800
Rep 4,668
Drives: F01 & F15 / Mineral White
First blooms of our Hibuscus
And surprisingly, my Fall Mums are still going strong in high 80 degrees!
lsturbointeg9152.50 |
05-15-2020, 01:15 PM | #932 |
Rep 14,522
Mums are popular out here in OH. Maybe I'll grab a few and put them in my containers?
05-15-2020, 01:28 PM | #933 |
"Salud"
13800
Rep 4,668
05-15-2020, 01:54 PM | #934 |
Rep 14,522
thanks Marcus! hopefully it turns out well
05-15-2020, 05:30 PM | #935 |
Rep 1,913
Just got a water pressure gauge delivered and measured 40 psi at an exterior spigot. Think I could try cranking it up a bit to get some more life out of my sprinklers? I’ve read to not exceed 70 psi, so thinking about trying about 50 - 55 psi. Newer home built in 2016.
05-16-2020, 03:05 PM | #936 |
Rep 1,913
Keeping the question game alive (I cranked up the pressure to the house this morning BTW... no toilets exploding yet)... Anyone try building their own privacy fence? I’ve got about 4000 sq ft of brush I’m going to clear while keeping the mature trees in place. Once I do that, I’m going to do ~340 linear feet of 6’ privacy fence (I’m thinking cedar pickets with treated pine for posts and crosses). I haven’t gotten any quotes for install, but I’m looking at roughly $3k in materials for DIY. I’d guess another $2.5k for install?
Anyone have any experience? |
05-19-2020, 03:58 PM | #937 |
Rep 374
I posted my Automower on here a while back. Love it, but my side yard's drainage was so bad it kept getting stuck or clogged with mud. Last weekend I finally tackled the beast.
Hand dug the first 100 feet, machine dug the second 100 feet. Tied in 4 downspouts and 2 wall drains Cut my cable line twice Hit my irrigation lines three times Got caught in a thunderstorm before I could re-fill the second half, so i got to bury it with soaking wet clay the next day and its a huge mess. Yard still looks like a construction zone, but when it rains the water flies out of the pop up heads by the road. Hoping it looks respectable again in a few weeks... |
sygazelle11345.50 AlpineWhite_SJ1578.00 |
05-19-2020, 04:47 PM | #938 |
17977
Rep 9,377
I had four WONDERFULLY SWEET blackberries off my bush last night. Sorry, gone before could be photographed. In MAY!!!
05-19-2020, 07:27 PM | #939 |
Rep 14,522
Sheesh...with all this rain I'm hoping I won't have to deal with fungus like last year
05-20-2020, 12:14 AM | #940 | |
Rep 1,024
While they were doing it it rained and they noticed seepage out of the ground from the neighbor’s higher elevation so they put a French drain under the manifold on that side. They wrapped up just as the shut down went into effect so one side is pretty much back to normal but the other side is a disaster area - half filled in and now that the stuff they dug out and piled to the side has baked in some heat, it’s as hard as concrete. Wasn’t cheap, but it’s backbreaking work - they dug mostly by hand with a pick to break up the hard parts. Saved a bit since they originally quoted a flat rate but offered to do time and materials. I think we got the manifolds and tie ins plus the French drain for what they originally quoted for just putting in the manifold for. |
05-20-2020, 12:16 AM | #941 |
Rep 1,024
05-20-2020, 12:00 PM | #942 |
"Salud"
13800
Rep 4,668
Our Celosia and Vincas starting to bloom for the Summer!
RickFLM410968.00 lsturbointeg9152.50 |
05-20-2020, 09:04 PM | #944 |
Rep 14,522
ordered my what use to be called CarbonX for my Memorial Day fertilizer app of the year
05-20-2020, 09:51 PM | #945 | |
Rep 3,411
I also installed an outdoor sump pump underground because there was a corner of the backyard patio that was to low to drain to the street naturally. I was hosing off the patio yesterday and thinking to myself, it was hard work putting it in but so worth the effort. |
05-21-2020, 12:17 AM | #946 |
Rep 1,024
Laid down the nematodes yesterday after the sun went over the horizon. Gotta water daily the next few days and hopefully they’ll get in the soil adequately before it heats up over the next few days.
Need to rototill some spots tomorrow and get the vegetables in the ground soon. Weekend project will be inspecting and re-staking the bubblers that are annoyingly on hose lines and not a timer/valve for the fruit trees and shrubs. |
