Originally Posted by msh441
Which is exactly what I want! Thanks.
I've now got the wiring diagram and information specific to the '07 E86 M Coupe. I've put it together with all voltage and fault testing info into this .pdf:
https://dl.dropboxusercontent.com/u/...ing%20Info.pdf
Shows exactly which color wire goes to to which specific pin on the seat, switch block, and fuse panel (in case its helpful for anyone else).
Combined with the BMW OEM E46 M3 retrofit harness (confirmed arrived at the dealer and forwarded on to me this AM!), with all OEM wire colors, plug ends, and pins...
...I should be in pretty good shape. I'm hoping all the wires are there. I may have to figure something out for wires running from the switch to the fuse panel, as the red/violet power wire is not present in the car, as I'd hoped. I THINK it'll be in the harness section I ordered, though (as all the seat-to-switch wiring is white/green/violet combos, and some brown/ground... and I think I can SEE red power wires in the bag with the others above-but they may actually be brown/ground) I'm in the ballpark at least, at this point, with the main issue being coupe interior disassembly! Worst case, I need to figure out 3 wires from the switch center to the fuse panel... but here's hoping they are there.
Hey, the dropbox link is no longer available, any chance you still have the file? Thanks!
