01-21-2015, 09:19 PM | #1 |
Retrograde
16
Rep 390
Part Out Thread - AirREX, Air Lift, OEM, etc.
So I hate to say it but I traded in my Z4 last week and now I have some things I'm trying to get rid of. I'm open to offers on most things but I think the prices are pretty fair. 1) Vossen VVS083 Silver - 19x8.5 et 30, 19x10 et 22 Brand New $950 shipped - SOLD 2) AirREX Bags/Struts $1300.00 (Retail is $2300.00 new plus one month+ wait time) 3) Air Lift Autopilot V2 Management SOLD 3.1) Air Lift 3 Gallon Tank and Viair 444c Compressor $180.00 shipped 4) OEM Red Trunk Light $50.00 shipped - SOLD 5) 25mm 42 Draft Designs Hubcentric Spacers w/bolts $80.00 shipped - SOLD 6) 15mm Hubcentric spacers w/bolts $50 shipped - SOLD 7) Black Tow Hook License Plate Holder (no hardware) $50.00 shipped ![]() ![]() ![]() ![]() ![]() ![]() I'll add more photos later tonight. ![]()
01-23-2015, 08:14 PM | #3 |
Retrograde
16
Rep 390
Brake light SOLD
01-26-2015, 06:21 PM | #5 | |
Retrograde
16
Rep 390
01-26-2015, 08:34 PM | #6 |
![]() 53
Rep 268
Just out of curiosity.
Does the tank hold a big enough charge that your first up/down motion happens immediately (and quickly)? Eg. My driveway has a pretty good incline and would need a higher stance... can you add air to the bags while driving just before you arrive? |
01-26-2015, 10:02 PM | #7 |
![]() ![]() ![]() 22
Rep 306
i have a similar setup on my sedan and i can answer this question hopefully for you torchmedia. the speed of the rise and fall depends more on the size of the lines, but with 1/8 or 1/4 lines you should be more than able to raise up seconds before a dip or bump or driveway. not sure how much travel his setup has but mine that has only a 3.5" travel holds about 2 full lifts worth of air. but this depends on the size of the air tank and obviously if it is full or not.
there is a sensor that kicks the motor on when the PSI drops below a preset level, but i am not sure how much air (what % of a full lift) at a minimum the preset/psi level is set to. mine hold about 2" of lift at a minimum which is still enough for me to avoid smashing into things. i also just want to state that this is an amazing deal on the air susp parts and that i don't think this price will come around again. if i didn't just get coilovers not long ago i would have this already in the mail on its way to my z4 ![]()
![]() Last edited by rusty_sojah; 01-26-2015 at 10:13 PM.. |
01-27-2015, 12:51 PM | #8 | ||
Retrograde
16
Rep 390
to add to that there have been a few times where I've seen something in the road and reacted quick enough to basically drive right over it. Same with speed bumps, driveways, etc. The management will kick on the compressor automatically at a minimum pressure you set to ensure that the tank is always full. So unless you're playing with the system at a stoplight or something and moments later you need to air all the way up you'll rarely find a time when the tank size isn't enough. Fortunately these cars are really light so the amount of air for lift is minimal when compared to other cars, also since its so light the 1/4" lines are somewhat quicker than say on a heavier sedan. Also included is the air tool hookup so you can fill tires, blow up balloon animals or what ever you can think of ![]()
01-29-2015, 09:46 AM | #9 |
![]() 53
Rep 268
PM sent with a question but i'll repost here:
Can you provide measurements of the tank/compressor setup so we can know if what you have will fit in an M Coupe trunk? |
01-29-2015, 11:04 PM | #10 | |
Retrograde
16
Rep 390
The setup I had was just the tank bolted to the floor with the compressor and valves behind it, clear of view from the opening of the trunk. So basically whoever buys the kit can put everything wherever they want since I don't have hard lines or anything permanent or specific. It would basically be like getting the parts from retailer and your creativity is your only limiting factor lol. But I'll get measurements of the tank in a bit and post them up. ![]()
01-30-2015, 04:40 PM | #12 | |
Retrograde
16
Rep 390
Ah yes, I forgot the battery is above the floor on the M. The tank (19") with the end fitting measures 2 feet wide x 10" deep. The Compressor is about 11" x 5"
03-01-2015, 12:55 PM | #16 |
Retrograde
16
Rep 390
Updated whats still up. Buyer backed out on suspension, management is pending.
03-01-2015, 12:58 PM | #17 |
Retrograde
16
Rep 390
and more pics...
03-17-2015, 02:58 PM | #18 |
Retrograde
16
Rep 390
03-28-2015, 04:54 PM | #19 |
Retrograde
16
Rep 390
Someone needs to jump on the bags. You won't find anything cheaper.
04-08-2015, 02:21 PM | #20 |
Retrograde
16
Rep 390
05-06-2015, 05:15 PM | #22 |
Retrograde
16
Rep 390
