11-10-2009, 10:35 PM | #1 |
Rep 4,320
Drives: '07 Z4 M Coupe
BMW Concept bike with straight 6
Didn't come up with any previous thread when I searched...
World Car Fans article "Who knows better than BMW how to build a straight-six powerplant? BMW Motorrad has decided to put its engineering prowess to create a motorbike with a straight-six engine. The Concept 6 was designed in Cafe Racer style and is intended to expand BMW's K-series model range sometime in the future. The straight-six is 10 cm slimmer than a traditional production 6-cylinder in order to be fit into the Concept 6 design. The 1.6 liter engine generates about the same amount of power as the straight-four of the K-Series but substantially more torque. 130 Nm of torque (96 lb-ft) already becomes available at 2,000 rpm. Fuel economy comparable to the straight-four is also had by means of E-gas technology. Design cues include the long front end and short back end feature of the classic Cafe Racer as well as the Split Face of current BMW Motorrad models. The suspension is a bridge frame made of light-alloy while Duolever and lightweight Paralever arms hold the front and rear wheels in place. A nifty LED display tells the driver how much torque is available at any given moment."
11-11-2009, 07:09 PM | #3 |
Rep 1,416
Drives: M-Sport 128i, 328xi, 3.0CS
Honda did that in the 70s.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
11-11-2009, 09:14 PM | #4 |
Rep 4,320
11-12-2009, 07:30 AM | #5 |
Rep 1,416
Absolutely not. The engine was so wide that you could easily scrape the cases in a tight turn.
11-12-2009, 07:59 AM | #6 |
Rep 2,200
at least honda understands the difference between sprung and unsprung weight (ie those goofy bmw forks)
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
Tags |
bmw motorrad, concept 6, motorcycle |
