      10-09-2019, 03:03 PM   #1
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
FS/FT: 2006 Z4M Coupe Street/Track (66K Miles)
Up for sale is my tested and proven 2006 Z4M Coupe street/track car to help fund a race car for 2020. No expenses were spared and only the highest quality parts were used to ensure reliability. Also considering trades for IS/IP, HS/HP, GTS3 or SE46 race car.
This Z4M is turn-key, ready to hit to the track and needs absolutely nothing. Professionally maintained and setup by Tyler Pappas from Tyspeed (Pikes Peak competitor & BMW CCA B-Mod 2018 Champion) and is fast. https://www.youtube.com/user/g35mr2/
- WGI: 2:07
- NJMP Lightning: 1:13
- NJMP Thunderbolt (No Chicane): 1:31
Silver Gray over Imola Red and Carbon leather. 66K miles, clean title and clean Carfax. VIN number and additional photos offered by request.
Asking $35,000
Located in Freehold, NJ
Clean NJ Title in Hand
All items listed below have been performed within the past 8K miles / 2.5yrs with receipts unless otherwise noted:
Current Weight:
3,140lbs w/o Driver & ¾ Tank of Fuel
Engine:
WPC Rod Bearings
RKTune Tune (No CEL)
CSF Aluminum Radiator
CSF Oil Cooler (Custom AN SS Lines and Mounting Brackets)
Valve Adjustment
Valve Cover Gasket
Rear Main Seal
Coil Packs
Spark Plugs
Timing Chain Tensioner
Rogue Vanos Line
Various Other Seals/Gaskets Updated/Replaced
Deleted EGR & AC Compressor/Condenser (OEM parts included)
BW EGR Block-off Plate
Exhaust:
SuperSprint V1 Headers
Rogue Engineering Exhaust (~30K miles)
Rogue Engineering X-Pipe (~30K miles)
OEM Secondary Higher Flow Cats still installed (no foul smell from exhaust)
Drivetrain:
Bimmerworld Solid Shifter
New OEM Clutch
Turner Solid Aluminum Motor & Trans Mounts
Turner Solid Aluminum Rear Subframe Mounts
Powerflex Black Poly Diff Bushings
Suspension:
JRZ RS2-NR (12 track days / <1K Street Miles)
Ground Control 800/900 Springs
Ground Control Race Camber Plates
Ground Control Solid Rear Shock Mounts
Ground Control Articulating Rear Spring Perches
Turner Race Rear Camber Arms
H&R Front Sway Bar
Turner Adj End Links
Powerflex Black Poly Bushings
Reinforced Sway Bar Mounts
Corner Balanced
Track Alignment
New OEM F/R Hubs
New OEM Front Control Arms
OEM M Front Strut Brace (rare)
Brakes:
Bimmerworld Brake Ducts
Custom Brake Cooling NACA Ducts on Underbody Panel
SS Lines
Motul 660 Fluid
Fresh OEM CSL Two-Piece Front Rotors (4 Track Days)
New Master Cylinder
Rebuilt Calipers (12 Track Days days / <1K Street Miles)
New OEM Street Pads
New Hawk DTC-70 Track Pads
Safety/Interior:
Wiechers Bolt-In 4-Point Roll Bar with X-Bar (All interior panels still fit without modifications) – 1 of 2 imported to the US from Germany
Sparco EVOII Seats (expired)
Sparco 6-point Belts (2022)
VAC Hardware
VAC Fire Extinguisher Mount w/ Extinguisher
Rennline Pedals
Jaffster Shift Knob
Wired for AIM SOLO DL & Smarty Cam
Braille #15 Battery (can swap with OEM if preferred)
Macht Schnell Battery Mount
** Mint condition OEM Imola Red seats can be added for an additional cost **
Body:
APR GTC-250 Wing
APR Splitter
Rolled Front Fenders
Turner Tow Straps
New OEM Windshield Cowl
New Safelite Windshield
Color matched front Reflectors
Black Kidney Grilles (OEM Included)
Square 18X9 et30 Alzor Wheels
--Apex ARC8 or D-Force w/ 275 Hoosiers can be added/replaced based on deal
275/35/18 BFGoodrich Rival Tires (200TW) (~12 Sessions)
--265/35/18 Hankook Ventus V12 Street Tires can be swapped if desired
BimmerWorld Race Studs (2 Track Days)
Wheel Spacers (Front: 3mm / Rear: 10mm)
      10-09-2019, 03:19 PM   #2
filtercoffee
I like Coffee & Z4s.
106
Drives: 2007 Z4MC
2007 BMW Z4MC  [0.00]
Such a beautifully built car but I'm so sad that you're selling it
Azeka1285.50
      10-09-2019, 03:27 PM   #3
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Thank you and it really is difficult to let this go. The Z4M is truly an amazing car that is both exciting and rewarding. I am so glad that I had the opportunity to drive it at its limits. Definitely going to regret this...
      10-10-2019, 11:34 AM   #4
NicoZ4M
Drives: 2007 BMW Z4M
Have seen this car multiple times in person and it is beautiful! Very well maintained by Tyspeed (i service my Z4M roadster there, fantastic shop!) and Afrim is a trustworthy guy. Buyer can purchase with confidence that they are getting a great car and deal here.
Sad to see her go
Azeka1285.50
      10-13-2019, 07:16 PM   #5
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Sold - thank you for the interest!
      10-27-2019, 10:05 AM   #6
3002 tii
3002 tii's Avatar
2282
Who’s the lucky buyer??
Follow for latest mods
      10-27-2019, 10:16 AM   #7
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Originally Posted by 3002 tii View Post
Who's the lucky buyer??
A couple very nice guys (brothers) from NYC picked it up within a day of posting it. They have a bunch of other cool track cars along with some classic M cars and track with HOD.
Hopefully we'll continue to see it being put to good use.
      10-27-2019, 12:13 PM   #8
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Congrats Azeka1!!!!
SO great that you created an incredible Z4MC.
Racerbruce
      10-27-2019, 01:25 PM   #9
3002 tii
3002 tii's Avatar
2282
Congrats man, definitely one of the nicest built DD cars on the board. Excited to see what’s next for you. Let me know if you have any leftover parts you’re looking to unload cheap
      10-28-2019, 11:43 AM   #10
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Thanks guys! I'll still be around and hope to get another one someday.
Only thing that I have left over is an OEM Z4M Front Swaybar with new OEM Endlinks.
