      12-20-2019, 02:50 PM   #1981
Emmrbee
Retired
Emmrbee's Avatar
Drives: 2006 Z4M Roadster
I read that very few were ordered in A43 green metallic. Sold mine last year to buy a low mileage Z4MR. The green always looked fantastic in the sunshine.
      12-20-2019, 05:55 PM   #1982
3002 tii
3002 tii's Avatar
Drives: Z4M, X3 35i, i3 REx
Genuine style 32’s (gen 2 version, concave instead of deep dish). Running staggered in this pic but also have 2 rears so I can run square.
While swapping things out I went with the shorter oe valve stems
Follow for latest mods
wdb1665.50
      12-22-2019, 12:18 PM   #1983
supergoat
Drives: 2013 328i Sedan M-Sport 6MT
Hydraulic fluid for the convertible top. It may not SOUND exciting, but being able to operate the top again under it's own power as opposed to my arm power is a treat. Luckily the motor is strong, just needed more fluid. Next on my list is either:
A) Properly fix the leak.
B) Ghetto fix the leak(Kind of already did that) and trade it in on an E89 which I've been considering for a while now. It's just hard for me to get rid of a super nice paid off car just to get a newer one and car payments again.
We'll see.
      12-22-2019, 06:41 PM   #1984
wyshyvanuk
Drives: 2008 Z4 MR
E46 Strut Bar. Easier than I thought.
wdb1665.50
      12-24-2019, 09:13 PM   #1985
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
Looks good. Which strut bar did you go with?
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      12-26-2019, 02:44 PM   #1986
3002 tii
3002 tii's Avatar
That’s the oe piece for e46 m3
      01-08-2020, 12:18 AM   #1987
3002 tii
3002 tii's Avatar
Played around with a low profile magnetic phone mount. Initially used windshield mounts but prefer a cleaner look and something closer to the accessory plug. I then tried vent clips which are great if you need it in sight for GPS but obviously gets in the way of ac/heat. So now this...
Dremeled a hole in the hidden HVAC panel and mounted one of those ball socket mounts. It’s really sturdy and allows me to use a 6” charging cord so less clutter. Only downside is it’s more upright than I thought it’d be (so you have to look down for GPS). But I’m ok with this as I just really wanted a convenient phone holder. Plus if I really need GPS I can easily mount it back on the ac vent. When not in use simply fold it down and it’s out of sight
      01-08-2020, 07:08 AM   #1988
wdb
dances with roads
wdb's Avatar
Drives: '07 Z4MC, '07 E93 328i
I use those but I stick them up on the dash to the right of the heater controls. (I have also successfully removed one from brushed aluminum trim.) They're very strong assemblies and magnets -- I hang an iPad Mini from them with no problem.
      01-08-2020, 09:16 AM   #1989
3002 tii
3002 tii's Avatar
I thought iPhone 11 Pro plus case and metal plate would be too much weight for the adhesive if mounted upside down so I just cut out a hole. If I was mounting right side up I agree it would’ve probably held up.
      01-10-2020, 11:28 AM   #1990
tomjones20194
Drives: 2004 Z4 2.5i
Originally Posted by tomjones20194 View Post
Bought new Koni yellow adjustables, Suplex springs and all the suspension bits to replace the struts/shocks on the car. Should hopefully ride / handle like new when I'm done with the install.
Quick update - I got the springs, struts, shocks and supporting bits installed over the holiday break. After about 500 miles on the new suspension, I have to say that this car is soooooo much fun to drive. Feels like it's on rails when cornering. I set the Konis to there softest setting, since the Z is now my daily driver. Combined with the new Suplex OEM springs, the ride is not harsh - just tight. It's wonderful.
3002 tii1230.50
      01-14-2020, 02:20 AM   #1991
TRiCC
TRiCC's Avatar
Drives: LSD equipped 3.0si Roadster
Complete cooling system overhaul (all 7 hoses excluding the heater hoses, reservoir tank, radiator, thermostat, waterpump, temperature/level sensors, and fresh coolant)
Was really overdue! 13 years old and 145k miles (bet the cooling capabilities of the old radiator unit was subpar due to how dirty and clogged the cooling fins are)
Minor suspension overhaul
Replaced my front lower control arms with new OEM ZHPs also overdue. (One of the balljoints was completely shot, lots of freeplay) and installed Ground Control School Coilovers
Also tryed out the weighted anatomic M shift knob (right). Love it more than the ZHP shift knob (left) its pictured next to!
3.0si GT - Z4 Hardtop Roadster Build
BPC Stage 2 Tune + Supersprint Headers + MFactory LSD + Stoptech BBK + Vibra-Tecnics Mounts + Ground Control Coilovers + H&R Sway + RECARO + BBS
wdb1665.50
      01-14-2020, 08:58 PM   #1992
yousefnjr
Drives: ‘06 Z4MR, ‘19 i3S
Originally Posted by yousefnjr View Post
A new electric friend 2019 i3s
Another new friend 2020 X7
The ugly BMWs are some of the best ones, I swear
H&R Coilovers | AFE Intake + Sound Generator | Stromung Cans | VT Engine Mounts | RE Trans Mounts | RE RSM's | Beisan Vanos Kit | Aero Skirts | VMR V803's | GTB Pedals | F10 M5 Knob | Alcantara Wheel | Black Kidneys | 4.10 Gears | CPI Stepped Headers | ESS Tune | DKF Catless S-Pipe | SS Brake Lines | AS SSK | CDV Delete
W///4187.00
      01-15-2020, 02:31 PM   #1993
W///
W///'s Avatar
4187
Drives: 08 E92 M3 /07 Z4MR / 99 E36 M3
See I think they look so much better in person, and the grille makes sense. I'm a huge fan of the G07, the car is so damn comfy! Congrats, that's a very nice fleet you got
Current: E92 M3 Sparkling Graphite/Bamboo Beige/6MT. E36 M3 Techno Violet/Dove/5MT. E85 Z4MR Alpine White/Imola Red/6MT
yousefnjr1506.00
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
