      07-15-2018, 06:24 PM   #1
mainsoda
mainsoda's Avatar
Drives: 2006 BMW Z4M coupe
ECS dip stick question
I bought an ECS dipstick and while it is really nice, when I lay it next to my stock dipstick the lengths seem a bit different.
The ECS seems shorter.
I've always had a bitch of a time reading the stock dipstick and the new one is super easy to read.
I think the oil reads high on the stock dipstick, but reads low on the ECS.
Am I crazy? Have you guys had any experience with this?
I'm changing my oil for the first time next week and from what I've read the S54 takes 5.5 to 6 liters. But I also understand that it never entirely drains all the oil out.
Is it really this difficult, are the Germans insane, or is it me?
      07-15-2018, 08:39 PM   #2
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
I have the ECS dipstick as well and based off my personal experenice it works 100% perfect as far as oil level.
mainsoda170.50
      07-15-2018, 08:53 PM   #3
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
My stock stick had always been difficult to remove. How is the ECS in this regards?
      07-16-2018, 08:02 AM   #4
mainsoda
mainsoda's Avatar
Like butter, it gets a little hot but it never sticks like the stock dipstick.
      07-16-2018, 09:40 AM   #5
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks. That's a plus for the ECS stick. However, your observation about it concerns me a bit to switch over. The ECS stick may be a bit shorter, but if you lay it down side by side with the top end lined up, does the MAX level on both sticks line up? The low end may not matters as much if it is indeed just a tad bit shorter.
      07-16-2018, 10:09 AM   #6
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
This. Max level definitely more important.
E85 ///M Roadster -SapphireBlack/Imola - Garage Queen
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      07-16-2018, 10:12 AM   #7
The HACK
The HACK's Avatar
1817
IF memory serves, the S54 has a semi dry-sump setup unlike most BMW engines. There's a full-on "wet" sump that the crank and the fuel pump share space with on the bottom of the engine, but there's also a secondary "dry" sump storage that stores an extra liter of oil to prevent oil starvation at high G forces.
Again, this is based purely on memory, but I recall in the owner's manual, it calls for reading the oil level after it's been warmed up (the car's been running for x numbers of minutes, oil up to operating temp at around 185º), then engine shut off, parked on level ground, wait 15 minutes then take a reading. If you take a reading right after you shut the car down, there's quite a bit of oil in the dry sump reservoir and you will read low. If you let the car sit for an extended period of time, the oil from the dry sump reservoir drains back into the wet sump and you will read HIGH.
Or it could just be the aftermarket dipstick is shorter.
mainsoda170.50
      07-20-2018, 02:27 PM   #8
mainsoda
mainsoda's Avatar
OK so I had quite a morning and I have what I think is a pretty good story.
So I am preparing to do an oil change tonight after work. I am still trying to figure out my dipstick issue here, but with the new knowledge that I need to warm the car up and turn it off and wait one minute before checking the level I get to work this morning with the car warm and park on a level spot in the parking lot. Then I grab my old stock dipstick and put it in to check the oil. As I'm pulling it out I hear a distinct snap and I pull the dipstick out to this horror.
Awesome, I just wanted to confirm my oil level compared to the ECS dipstick and now I have a piece of plastic lodged in my dipstick shaft.
I just bought a Topsider oil extractor so I thought I might try my hand at using this to suck it out. Yeah I know what your thinking, and it didn't work. I tried 10 times.
So at this point I figure I might as well try to drain the oil and see what happens. I get just about all the oil out (the Topsider is awesome) and as I go to pull the tube out of the dipstick I hear a clink. I thought I might have imagined it so I did it again, same clink! So i put the tube in a third time and draw it out very very slowly. Then to my extreme delight I see the red plastic end come out of the tube. I fist pumped and and exalted more joyously than I like to admit.
So I'm still not exactly sure how to check my oil, but I feel good that my engine won't explode from plastic bits.
I fill the new oil as I measure the old oil taken out so as to leave it the same. The oil looks the same on my aftermarket dipstick . Here is my issue with the dipsticks incompatibility. Do I have a bad stock dipstick or a bad aftermarket dipstick? What do you guys think?
XMetal1096.50
StickMon635.00
      07-20-2018, 03:29 PM   #9
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks for the update and pictures. I would definitely raise the issue with ECS. Their stick will cause you to overfill
mainsoda170.50
      07-20-2018, 03:36 PM   #10
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Agreed, that doesn't look right at all. From what I've seen (never had to use myself), ECSTuning has good, responsive customer support.
They offer a number of similar dip sticks for different vehicles so it's possible this was a mispack.
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
mainsoda170.50
      07-20-2018, 05:23 PM   #11
mainsoda
mainsoda's Avatar
I did contact ECS and they said they are looking into a possible wrong part. So far they have only sent me a return procedure, but I don't want to return it.
They did confirm that the M3 and the Z4M S54 engines are the same.
I don't know what is going on exactly, but I know one thing for sure. I will never put that stock plastic dipstick in my car ever again. That end snapping off scared the crap out of me.
      07-20-2018, 05:56 PM   #12
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
Why not return it? It is useless to you, as the min/max ranges are way off of the OEM dipstick.
Let us know how this turns out. That stock one breaking off like that is certainly concerning.
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      07-20-2018, 07:42 PM   #13
mainsoda
mainsoda's Avatar
Really the only reason I need it right now is becuase it's the only working dipstick I have.
      07-20-2018, 07:59 PM   #14
gpraceman
gpraceman's Avatar
Not really, as if the oil level showed up on that ECS dipstick, you will be well above the max mark. Other than keeping the dipstick tube covered until you get a usable replacement (the broken one can do that), the ECS one is doing you no good.
      07-21-2018, 06:56 PM   #15
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
Forgot to mention earlier. I think it's either a incorrect ECS dipstick or faulty. First thing I did when I got mine was measure my stock with the ECS and it was exactly the same.
      07-21-2018, 07:50 PM   #16
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
What's the ECS part number? It's difficult to find the correct one on their website. Thanks.
      07-21-2018, 09:27 PM   #17
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
This is the one on my receipt.
https://www.ecstuning.com/b-ecs-part...422ecs01-03~a/
XMetal1096.50
      07-21-2018, 11:35 PM   #18
gpraceman
gpraceman's Avatar
Was that the part# on the packaging for the dip stick that you received? I bet they just grabbed the dip stick meant for a different engine.
      07-21-2018, 11:39 PM   #19
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
I have no idea bud, it was 7 months ago.
      07-21-2018, 11:43 PM   #20
gpraceman
gpraceman's Avatar
Sorry, seemed like it was something that you had just bought.
Looking on the ECS website, they do offer dipsticks that look like that for other engines. So, they likely just sent you the wrong one. Being so long since you bought it, hopefully ECS will work with you on getting you the correct one.
      07-22-2018, 01:59 AM   #21
mainsoda
mainsoda's Avatar
This is the stick that I have.
View post on imgur.com
XMetal1096.50
      07-22-2018, 12:15 PM   #22
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks for posting the part number - their website does so that it's for our cars. Definitely get them to replace it for you.
I just placed an order for one. First thing to do will be to compare it to my OE - Will report back when I receive mine
Search this Thread:
Advanced Search
