Go Back   ZPOST > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
      11-22-2019, 09:44 AM   #89
Emilime75
Drives: 2010 335i E92 LeMans Blue
Something that doesn't get a lot of love in the U.S...the Toyota/Lexus 1uzfe. 4.0 V8, DOHC, 6200 redline(6500 for the VVTI version). Not a power house by any means, but torquey as a V8 should be and a lot of fun in my 95 SC400 project car. Sadly, the V8 SCs only came with automatics, but manual conversions exist and I'm planning on one. With a straight through exhaust, this thing sounds really, really good, and lowered on coilovers and poly suspension bushings has made the Luxo coupe a real driver.
      11-22-2019, 02:21 PM   #90
Z06Driver
Drives: AW E92, MG F32 440i
Originally Posted by FuriouslyFast View Post
Then C6Z needs to be in this thread.
yes sweet motor until it drops a valve
      11-22-2019, 02:39 PM   #91
Salty Dog
Salty Dog's Avatar
3575
Drives: Austin Mini,MBGLK, Porsche 993
That has happened to me twice on my daily, not V8's both turbos and just for good measure the valve bits blew threw the hair dryer just to add some more cash to the repair bill.
      11-22-2019, 03:55 PM   #92
jimbobiggens
jimbobiggens's Avatar
Drives: 2013 335i xDrive
Hard to beat the sound of old school fury. Here is one seriously angry Ford.
https://youtu.be/yKn2IFdTQvU
I'm not completely useless, I can be used as a bad example.
N54Yankee2707.00
Salty Dog3574.50
      11-25-2019, 07:45 AM   #93
FuriouslyFast
Drives: Miss Daisy
Do the heads then. Common sense at this point. Mine was reliable, but thanks for chiming in.
Rmtt8211.00
      11-25-2019, 11:11 AM   #94
Rmtt
Rmtt's Avatar
Drives: 2011 BMW 128i, 2008 LS3 C6
Same here. I bought a car that already had the issue addressed. Kind of like looking for an M3 with the Rod Bearings already done.
I beat the crap out of mine and pretty much every model I have ever owned and it just seemed to continue to beg for more!
Everybody has a gameplan....until they get punched in the mouth.
      11-25-2019, 11:22 AM   #95
See5
BMW Fan
See5's Avatar
Drives: Nothing
My 2013 Boss 302 had the redline set at 7900rpm and had no problem making power at that speed.
I see that no one has mentioned the Miata. The later NC models will rev out to 7500rpm before fuel cut.
      11-26-2019, 10:29 AM   #96
FuriouslyFast
Drives: Miss Daisy
I mentioned the Miata a while ago & was told S2K & no Miata lol
      11-26-2019, 10:41 AM   #97
Red Bread
Drives: Smog machines
He's at least talking the new ND motor, which I gave partial credit to. The NA-NC still don't rev though and benefit from shifting under redline.
      11-26-2019, 11:41 AM   #98
ntg44
ntg44's Avatar
Drives: R8 4.2 Spyder
Question - because my friend has a '12 Boss 302 and he told me he spoke with engineers of the car when he went to that driving school you get with the purchase. According to him, they mentioned that the reason the engine redlines at 7500 RPM is because the ECU can't keep up with the calculations at a higher RPM - this was the reason that the car feels like it keeps making power until the abrupt fuel cutoff at 7500.
Just curious - did you need to make any hardware changes along with raising the rev limiter, or was my friend misinformed with a bunch of hogwash?
Thanks
      11-26-2019, 12:32 PM   #99
pennsiveguy
pennsiveguy's Avatar
Drives: F15 xDrive50i M-sport
Thanks
I can't speak from authority as an engineer, but it makes sense. Any processor has limits as to calculations per unit of time and data throughput. In an 8-cylinder engine with 32 valves and 8 coils and plugs, there's a lot of things happening every millisecond at high revs. At 7200 RPM, that's 120 revs per second, or .12 revs per millisecond. In that millisecond where the engine makes about 1/8 of a revolution, several valves will be in motion, a plug will fire, etc. If the ECU is only able to capture a small sample of the events that are happening then it'll be ineffective at regulating the engine, and efficiency and durability will suffer.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
      11-26-2019, 12:38 PM   #100
ntg44
ntg44's Avatar
I also understand why it makes sense hypothetically, but if see5 was able to increase it 400 RPM and make power without a piggyback, coprocessor, or standalone ECU of some sort, then my friend is going to be really interested to know this haha.
      11-26-2019, 01:04 PM   #101
RM7
RM7's Avatar
2893
Drives: Camaro SS 1LE
You don’t really know of it was “making power” unless you dynoed it. My 2.0 would happily rev above 7, it seemed fast cuz I was going fast, but it wasn’t producing it’s peak hp and especially not torque. Fun and loud, but not really accomplished anything.
      11-26-2019, 01:27 PM   #102
FuriouslyFast
Drives: Miss Daisy
What? They benefit from being revved up. I've owned 3 NAs (One boosted) & my current NB Mazdaspeed Miata...
My MSM doesn't make full power until 6K RPM for crying out loud
      11-26-2019, 02:10 PM   #103
RM7
RM7's Avatar
2893
And then what happens, does it make MOAR power?
Red Bread4463.00
      11-26-2019, 02:24 PM   #104
jimbobiggens
You know that engineer was pulling your leg about that computer not being able to keep up, right?
The 1987 5.0 Mustang GT was advertised as having an ECU that was more powerful than the computer used to go to the moon in 1969. The EEC-IV, as it was called, is capable of performing a million calculations a second while running at a measly (by today's standards) 15mhz. This 22 year old EEC-IV was used in Formula 1 at the time. High rpm's were not a problem.
And that ECU is an antique by today's standards.
N54Yankee2707.00
      11-26-2019, 04:04 PM   #105
9krpmrx8
Clean is the new cool, keep it that way.
9krpmrx8's Avatar
808
Drives: 11' Alpine White 335i Sedan
My Rx-8 was fun, miss the handling and high revving nature. But it needed more power for sure, even with a turbo it needed much more but the engines are just shit reliability wise.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive
SherM4n630.00
      11-26-2019, 05:11 PM   #106
Red Bread
My dad's ND was dead reliable. He might have had the only one. For the street, the sequential turbo thing was pretty ideal. Provided it wasn't hot out. Or raining. Or too humid. Or too dry.
      11-26-2019, 05:11 PM   #107
FuriouslyFast
Drives: Miss Daisy
Are you blind?
      11-26-2019, 05:14 PM   #108
Red Bread
Exactly. Power peaks at 6k and just fades off after that. Methinks you've never had what this thread is talking about. Corvettes, Miatas, Challengers and an MS6 are not rev happy cars. [IMG]http://www.knacktoys.com/CARB/2005BaseMap.jpg[/IMG]
[IMG]https://www.belltuning.com/media/wys...EDLINE.png.jpg[/IMG]
      11-26-2019, 05:19 PM   #109
FuriouslyFast
Drives: Miss Daisy
Me thinks you cannot read. Enjoy your ginger bread!
      11-26-2019, 05:29 PM   #110
Red Bread
Extra high revving ginger. Maybe you should try it?
