12-10-2018, 09:10 AM | #1 |
Rep 29
Need to replace steering rack in '06 Z4 M
Greetings fellow Zed Heads -
Just found out from my mechanic that I need to replace the steering rack in my M. Of course, they can find none in the US and it has to be ordered from Germany. The price is insane at $2,900 including labor. Anyone know of a rebuilt or newer steering rack that they have laying around they'd like to sell. Much appreciated! |
12-10-2018, 11:37 AM | #2 |
your average JAMF
3097
Rep 4,093
Is it a roadster? If so this guy has a rebuilt one available for $600...
https://shop.rackdoctor.net/Z4-SERIES_c88.htm If a coupe - that's a different rack, you might still reach out to him about sourcing one or getting yours rebuilt there. He's in SC so not like having to deal with Europe. Good luck!
'21 M2 Comp
'19 Golf R |
12-10-2018, 02:24 PM | #4 |
Rep 1,130
I came on this forum to start a thread about my rack and pinion (R&P) needing replacement and what my best options are. Then I run into this thread lol.
I found this site, happens to be the same one (I think) that Kevin pointed out: https://rackdr.com/2006-2008-bmw-z4-...0aAnOmEALw_wcB My story: I went in to this "expert" shop on wheel alignments. They have state of the art machines of course. With the alignment, they provide a free suspension check up. The guys were car enthusiasts and ended up giving a free check up and told me to hold off on the alignment because my rack and pinion needed replacement. They quoted me $126 for labor to replace the R&P and $69 for the alignment. They had the car up on the lift. One of the guys stayed in the car and steered left and right back and forth. There was a knock inside the rack, could hear it and feel it at the same time. He said that there was small play in there and it's supposed to be STILL when steering. He also pointed out my control arms, control arm bushings, tie rod ends, brakes and rotors seem to be all new and in good condition. I did replace all that less than 2 years ago. The rack and pinion goes for $1500-$2500 everywhere online. The only one at a "decent" price is this rack doctor website. Does anyone have experience shopping from there?
2014 BMW X5 Sdrive35i F15
12-10-2018, 02:45 PM | #5 |
Rep 29
I did check with my mechanic and they won't purchase from that site because they can't offer a warranty on it. But I'm going to go ahead and buy it from Rack Doctor(unless someone pings in with a better solution) and have it shipped to my mechanic and they will install for me. I do see that they offer a refund if you send them the original core, so that's a nice touch) I'm not capable(more like willing LOL) of doing the work myself, just not in my nature.
12-10-2018, 03:28 PM | #6 | |
Rep 1,130
I was thinking of doing it myself, but $126 for labor isn't really much to have that peace of mind that my steering and suspension is all done correctly.
12-10-2018, 07:02 PM | #9 |
636
Rep 3,124
$126 for labor? Wow.
I'd figure somebody would charge that much to replace a light bulb.
WeekendWarriorz670.00 |
12-10-2018, 11:18 PM | #10 |
your average JAMF
3097
Rep 4,093
Well hopefully this turns out well! Glad I was able to turn that guy up. For $600 vs $2900, I'd sure as hell roll the dice. This guy talks a good game, hopefully the finished product lives up to it. Offering a lifetime guarantee would seem to be a good sign. Good luck and keep us posted!
'21 M2 Comp
'19 Golf R |
12-11-2018, 01:30 PM | #11 | |
Rep 3,004
Steering rack
How many miles on the vehicle? Typical usage (daily driver, track car).
Racerbruce
12-11-2018, 02:50 PM | #12 | |
Rep 1,130
I was hit a few years back, mine must've been damaged from the accident is my guess.
wdb4718.00 |
12-11-2018, 03:44 PM | #13 | |
Rep 3,004
Steering rack
Perhaps the accident did cause this; curious if you noted a difference in the steering after the accident; were the front tires hit? Or did your Z4M run over a curb?
Racerbruce
12-12-2018, 12:31 AM | #14 |
Rep 1,130
I was hit on the rear passenger side, spun about 8 times in the road, followed by a slam on the curb. Both passenger wheels hit the curb at about the same time. My rear wheel broke and front wheel cracked. They were both replaced along with suspension components in front and rear. No damage to the frame. After the accident (and after the repair), i did notice a difference in the steering. It had been repaired by my local BMW dealer and covered by my insurance. They replaced the obvious things to the naked eye, but I then chose to take it to my mechanic. We put it up on the lift and he showed me the damaged tie rod ends and control arms. While we were in there, he suggested To replace rotors, brakes, control arm bushings, I also upgraded springs and shocks. Car felt better but didn’t feel the way it did prior to the accident. Kept driving it a few years until the loud clunk (felt and heard it coming from underneath the driver’s side) became more present. The only reason I took it to get an alignment is because in order to make it go straight, I have to have my steering wheel turned a bit to the left. The guys at this shop checked all components in front and after I told them about the vibration at 80MPH, they pointed out the rack and pinion as the culprit. This explains the vibration and also the loud clunk when turning the wheel. I wouldn’t worry about it if you haven’t had any sort of accident. I don’t believe it’s an item that just wears out after 100k miles.
12-12-2018, 09:27 AM | #15 | |
Rep 3,004
Steering rack
Racerbruce
RossBMWZseries224.00 |
12-12-2018, 04:42 PM | #16 |
Rep 2,720
Check this junkyard if you already not have ordered.
Specializedgerman.com Call them, they are really good in providing parts with good information!! V god price with warranty. |
12-19-2018, 01:58 PM | #17 |
Rep 29
Update for you guys:
I did order it from Rack Doctor and should get delivered in the next couple of weeks to my shop. I will let you know once it has arrived and has been installed and my and my mechanics thoughts after the work is complete. And to answer racerbruce's question - I have 46k miles on the car, it is a semi daily driver - 2-3 times a week if weather permits. I don't like taking her out in the rain and my SUV's are there for the snow, etc. Some track time, but not a lot. I honestly can't feel any difference with the current column in place now and have had no issues. But it is definitely leaking and needs to be replaced. Glad this isn't a common issue and hopefully this rebuilt rack and pinion will resolve all challenges. |
12-19-2018, 04:39 PM | #18 | |
Rep 3,004
Parts ordered....
Thank you for answering the questions - perhaps install in late Jan?
Racerbruce
01-02-2019, 10:32 AM | #19 |
Rep 29
So, I got an email from Rack Doctor cancelling my order and called them today. They don't have any in stock currently, but will rebuild yours if you send it to them and offer a lifetime warranty on their work.
I'm going to have my mechanic pull it and ship it to them and they said they would normally be able to rebuild in 24-48 hours upon receipt and then shipping back up to DC is 24 hours. So, although a bit convoluted, it will still do the trick. And it's winter, so not a lot of time in the M right now anyway. Will update once the work has been done to let you all know of the satisfaction with their work. But, super friendly on the phone.
2006 BMW Z4M
2015 BMW 435i 2011 BMW X5 50i 2010 Porsche GT2 2012 Ford Expedition |
01-02-2019, 11:00 AM | #20 | |
Rep 3,004
Steering rack rebuild
A minor setback - hopeful the rebuild is as planned and you're taken care of soon.
Racerbruce
01-02-2019, 12:05 PM | #21 | |
Rep 2,720
They have huge inventory of German cars. Very good response And my parts came nicely packed, properly marked with 6 month warranty. Great price too. Good luck. |
01-02-2019, 05:38 PM | #22 | |
Rep 29
Thanks for the heads up!
2006 BMW Z4M
