12-02-2018, 01:44 PM | #1 |
Rep 175
H&R 5mm spacers for BMW with extended lugs
I'm selling a pair of 5mm h&r spacers I put on my z4m to test fit for new wheels I put but they were not big enough to space out my wheels. It was only mounted once and driven around the block. Still like new. Wheel Spacer Set (5mm) (Black) by H&R H&R DR Series Wheel Spacer Spacer fits between the wheel and hub. Requires the use of extended wheel bolts or wheel studs. Also requires the use of the OEM wheel hub to center the wheels. Spacer Thickness: 5mm Bolt Pattern: 5 lug x 120mm Center Bore: 72.5mm Wheel Bolt Thread: 12x1.5 Asking 45+ shipping for the spacers plus the extended bolt lugs. Last edited by rueyme; 12-02-2018 at 01:51 PM.. |
