12-22-2018, 11:35 AM | #1 |
Rep 232
Battery removal help
I'm finally getting to replacing my battery on my Z4M after it died on me. I took all the panels off but cant figure out to remove the top plastic cover that sits right on top of the battery.
[IMG][/IMG]
'06 Z4MR
Black sapphire / Imola Last edited by Andyh1; 12-22-2018 at 11:44 AM.. |
12-22-2018, 12:47 PM | #2 |
Rep 66
Drives: 06 Z4M Roadster; 2012 Cayenne
12-22-2018, 12:57 PM | #4 |
Rep 1,130
As you can see the in the video above, that piece comes off as ONE piece. In your picture, looks like you removed the carpeted part and left the plastic trim on top. You’ll need to remove that tire mobility kit (black box you see in the far back at the top). Simply remove it and right under on the plastic tray, you’ll see or feel 3 nuts. Remove them with a 10mm socket, then that trim will come right off.
Now to the battery.. Remove the negative cable using a socket, don’t recall the size. Once you get to the positive in the back, there’s 2 nuts pretty close to each other. You wanna remove the smaller one because the bigger nut will only remove the BST, which is NOT what you want to do here. You can have more access if you flip up the convertible top tray. |
kaybat125.50 |
12-22-2018, 01:18 PM | #5 | |
Rep 232
01-06-2019, 02:51 AM | #6 |
Rep 65
Drives: 07 Z4M Coupe
Just wondering is it common for the battery hold down (axial securing clip) to rust? I just changed the battery for the first time was surprised to find it in that condition.
01-06-2019, 01:19 PM | #7 | ||
Rep 2,866
Drives: Anything
1. Leaking battery 2. Unvented battery to the outside (acid fumes in the area) 3. The area was submerged in water at one time FYI - The battery hold down on both of my 10yr old Z4 and 15yr old X5 are rust free and looks brand new. |
01-09-2019, 10:26 PM | #8 |
Rep 232
The alternator was slowly draining the battery and not recharging it properly. I'll bought a new battery, waiting to replace alternator next month. Car is sleeping this winter.
