      06-18-2020, 03:48 PM   #1
MadGus
Drives: 2006 Z4MR
2006 BMW Z4MR  [0.00]
'06 Z4MR - uneven tire wear
Hi folks. 57.5k miles on the clock, and I'm looking to replace my two rear tires with Michelin PS4s (stock size on stock wheels).
Current rear tires are wearing on the outside faster than on the inside, which tells me I need an alignment. The rear shocks and springs are original stock. I don't track this car.
My question: should I go ahead and upgrade my rear shocks (with Bilstein B6, new mounts and bump stops) before getting an alignment with the new rubber on the rears?
My local indie shop charges $195 for an alignment.
      06-19-2020, 01:53 AM   #2
pyshin
pyshin's Avatar
Drives: 97c2
Yes
      06-21-2020, 05:14 AM   #3
MadGus
Drives: 2006 Z4MR
Originally Posted by pyshin View Post
Yes
Because installing new shocks will push the wheels out of proper alignment if I do that later?
      06-21-2020, 09:05 AM   #4
pyshin
pyshin's Avatar
Drives: 97c2
Positive camber in the rear (wearing faster on the outside of the tire) points to an abnormality in the suspension somewhere; when replacing things (especially on a 14-year-old car) I tend to err on the side of caution and replace complementary parts. If you trust your mechanic have them inspect your suspension and see if anything warrants replacement, you may be fine with just replacing the tires and getting a proper alignment.
      06-21-2020, 06:55 PM   #5
Clearancediver
Drives: 2004 Z4
Nope...replace shocks.
Replacing shocks is a reasonably easy-medium DIY. It's more likely true that the shocks need replacing than the shocks are in good condition.
Sent from my smart phone...
      06-23-2020, 05:04 AM   #6
MadGus
Drives: 2006 Z4MR
Thanks to both of you! Very helpful.
