06-01-2013, 07:36 PM | #1 |
Rep 153
Rhino Ramps?
Does anyone know if my '04 Roadster's front bumper will clear the ramps? If not, how do I get my car up on two jack stands if I'm using the jack pads to jack the car up?
06-01-2013, 08:03 PM | #2 |
Rep 178
I have no clue if they will clear, but I had Rhino ramps when I had my S2000. You could back up on to it without issues, but to get the front end on you would have to put down a few 2x4 wood planks in front to ease the transition. but its a cheap enough solution.
06-01-2013, 08:09 PM | #3 |
Rep 2,782
I had Rhino Ramps. They won't clear.
56" Race Ramps barely clear. They're one of my favorite purchases.
06-01-2013, 10:51 PM | #4 | |
enthusiast
48
Rep 1,695
There are more tricks if you need to put 4 jack stands under the car. Don't know anything about ramps. |
06-02-2013, 12:46 AM | #5 |
Rep 384
I use them on my 3.0si. Take a couple of 2x8 boards and stack them overlapped on the front of the ramps. Its just enough to lift the bumper and keep it from hitting the ramp.
06-02-2013, 07:34 AM | #6 |
Rep 51
ramps
06-02-2013, 08:05 PM | #7 |
Rep 153
06-02-2013, 10:42 PM | #8 |
636
Rep 3,124
It makes some people cringe, but I've had the car up on 4 jackstands about 30 times jacking it under the pinch weld. I took the top off my jack and replaced it with a 1 foot piece of 2x4 to spread the force.
08-19-2019, 07:38 PM | #10 |
2013 E93 M3 MW/Fox and 2018 X5 M Sport
41
Rep 38
Drives: 2013 E93
Digging up an old thread...
I've been using jacks to raise the car but wanted something a little quicker and cheaper than race ramps. Rhino ramps are cheap and about the only commercially off the shelf product around here. I did some reading of the threads and thought I'd give them a try as they were on sale and I can use them for my other vehicles. What I like: Wide, tough, relatively short, stackable and cheap. What I don't like: Steep angle, not enough clearance for front of M3. There is plenty of clearance to back up my e93 M3 onto the ramps. In doing that tho there is not enough clearance to get my low profile jack under the front bumper to access the central jack point to raise the car. Even with a standard piece of wood that's 1.5 inch thick, it's about a 1/4 inch too low. Same as with the car sitting on all 4s. I double up the wood on the front to get a lot of clearance by throwing some 2x12s together but as other posts have suggested, you can add a two foot section (or longer) to lower the angle and drive the front wheels up into the ramp. I didn't have enough wood long enough to this so adapted to get all 4 wheels off the ground to access the central jack. As a result, I don't think Rhino ramps make it any easier or faster to get the car in the air. Their 7 inches of height is nice when working under the car for any length of time and if you only have two jack stands it might be beneficial, otherwise... |
08-19-2019, 07:40 PM | #11 |
41
Rep 38
Drives: 2013 E93
Pic
Rear spacing
08-20-2019, 01:49 PM | #12 |
Rep 1,130
I've been using Rhino ramps for years now. I used to stick two 2x4 wood planks on each ramp to allow the car to drive up without an issue. Driving the rear up is much easier and 2x4's aren't necessary. However, I now have the Schmiedmann front lip, there's no way it'll go up the ramps, not even with wood planks.
Solution: Get a long low profile jack, and lift up the front center jack point. My low profile jack isn't the long extended version, so I just jack up the side of the car and slide the ramp under the tire, repeat for the other side. It is more work and there's not many solutions out there when you have a low profile car.
2014 BMW X5 Sdrive35i F15
08-24-2019, 05:17 PM | #13 |
dances with roads
4717
Rep 4,094
I have an ancient pair of steel ramps. Very steep angle. I bought a 2x12 and made a pair of "pre-ramps" to get my low cars up onto them. Cheap, easy. Not lightweight, not compact, so I wouldn't call it a track day solution unless you tow. But in the garage (or in the driveway, where I first started using them) they're fine.
