      06-26-2012, 05:52 AM   #1
Karacticus
Karacticus's Avatar
Drives: 2007 Z4 3.0si Coupe
"Hero" shots from the Rites O' Spring BMW CCA HPDE at Putnam Park
First time at this track. Excellent facility and a great track for working on handling.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
      06-26-2012, 06:46 AM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
nice pics!
      06-26-2012, 06:47 AM   #3
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
Now lets see some footage off that GoPro!
      06-26-2012, 08:33 AM   #4
Karacticus
Karacticus's Avatar
I'll put up some of the GoPro footage once a get a chance to edit it. I've got some good footage of traffic from late passes that's pretty neat, including a Lambo that was in attendance...
2007 3.0si Coupe
      06-27-2012, 06:42 PM   #5
Karacticus
Karacticus's Avatar
Video
Had the track to myself the last several laps on Sunday. Unfortunately both the car and I were getting too hot and too tired to do more than about 6 or 7 tenths.
2007 3.0si Coupe
      06-27-2012, 09:34 PM   #6
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
cool spot to mount the camera!
///M - Some Mods 'N Stuff
      06-27-2012, 10:38 PM   #7
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Love where you put the GoPro! Simply Perfect! You get the sound of the engine also and less wind blowing. I'm gonna try that for my next track day! Thanks for sharing
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      06-28-2012, 03:57 AM   #8
3798j
3798j's Avatar
11409
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
The sounds and viewpoint were wonderful. That was neat.
      06-28-2012, 08:24 AM   #9
3002 tii
3002 tii's Avatar
2282
I'm thinking about mounting mine there for the next event as well. I just always cringe though every time I pop out the grill... it's only a matter of time before some piece of plastic breaks. I'm so terrible at finesse things, I always use brute strength lol.
Follow for latest mods
      06-28-2012, 08:39 AM   #10
JasonH
JasonH's Avatar
Drives: 2007 M Coupe, 2003 M3 Vert
Nice video. Did you have the open or closed back on the camera? I'm thinking of just zip-tying the GoPro plate mount to my grille which should have a similar result.
      06-28-2012, 09:42 AM   #11
Karacticus
Karacticus's Avatar
Yeah, I've got broken tabs for the grill, mostly inboard and upper-- never broke them putting the camera in and out, but from back before I figured out how to best insert and remove the grill for other reason.
Here's a link off to a post (on a different forum) that shows the installation.
http://www.bimmerfest.com/forums/sho...59&postcount=8
I'm currently using the open back on the full (not skeleton) case with a mic muffler on the back. Kind of looks like a raccoon toupee. Here's a link to the site I purchased it from. I'm also using their drop in polarizing filter.
http://www.eyeofmineactioncameras.co...uct_p/micv.htm
Edit: I also try to raise the hood between sessions, as I've seen some issues from heatsoak back into the camera. It lets me pretend I'm one of the forced induction guys...
2007 3.0si Coupe
      06-28-2012, 11:43 AM   #12
3002 tii
3002 tii's Avatar
2282
You're actually mounting on the bar? I thought you did it on the bumper support.
That slipover piece is hilarious, is it actually effective? Is it that bad using the open back?
      06-28-2012, 11:57 AM   #13
JasonH
JasonH's Avatar
Very cool. Thanks for the info. Oh, does the skeleton back help with the camera overheating? Have you considered using the full skeleton case? Or do you think that's too risky on the track even on dry days?
      06-28-2012, 12:59 PM   #14
Karacticus
Karacticus's Avatar
I only had the heat problem once late in the day while waiting an extended time on the grid with the engine running and the A/C off, which results in the fan not running continuously, at least at temperatures of that day.
I figure leaving the hood up makes sure the camera is as cool as possible before hitting the grid.
I tried this position with pretty much all of the combinations of cases, backs etc, and I think I'm getting the best sound with the open back and the mic cover. YMMV
My impression is that the mic cover helps with some of the low freq wind noise. However, there's still plenty noise if I use it in other locations, so it may be the lower velocity air in front of the radiator along with just plain saturating the mic with intake noise that's producing the desired result.
2007 3.0si Coupe
      07-12-2012, 07:06 PM   #15
3002 tii
3002 tii's Avatar
2282
btw did you use the roll bar mount or handlebar mount?
      07-12-2012, 07:15 PM   #16
Karacticus
Karacticus's Avatar
Handlebar/seat post mount.
I'm wondering if you might also be able to set something up with one of the self adhesive mounts on the back side of that radiator bulkhead just behind the grill. However, the good think about the mounting I'm using is that everything is bolted/clamped on.
2007 3.0si Coupe
      07-13-2012, 06:02 AM   #17
3002 tii
3002 tii's Avatar
2282
So what exactly do you mean by heatsoak for the camera?
      07-14-2012, 12:09 PM   #18
Karacticus
Karacticus's Avatar
I had one occurrence where, when waiting for an extended time on the grid with a warm, but shut down engine, the camera posted an error code and failed to record the session. It was also hot and facing towards the sun.
I figure the camera just took a little too much heat, so now I raise the hood between sessions to let the heat out from under the hood instead of soaking back though the radiator and through to the camera.
Don't know if it really helps, but figure it can't hurt.
2007 3.0si Coupe
