04-18-2008, 11:08 PM | #1 |
El Greco Capitan
309
Rep 1,051
Electric Soft top Died :(
Hey guys, tried to search but couldn't find much.....!
My Locking mechanism seems to be working since it locks the top in place however my motor died.. The top is in the full up locked position and when the button is pressed it unlocks and it just stays there dead....! BMW Rep said 1400.00 for a new motor.....Is this something that can be done on the outside by an independent garage shop? Thx for your help. |
04-18-2008, 11:23 PM | #2 |
Rep 367
The entire top needs to be removed to replace the motor. Most likely the motor took on water due to a clogged drain and failed.
If you find an Indy shop willing to do it, give it a try, but most likely you will have to get it done at the dealer
08 Z4 3.0SI Black Sapphire/Black Int, 6sp, Sport/Premium --- retired --- 2010 BMW 650GS -- Z4 replacement Working with the most talented people on the most technically advanced automobiles.... |
04-19-2008, 04:26 AM | #4 | |
Rep 2,128
They did, but they underestimated her. The drain holes are small and clog easily - the problem is common on cars kept outside and uncovered, as leaves, twigs, and pine needles clog the drains. Cars kept garaged avoid the problem usually. |
04-19-2008, 04:31 AM | #5 | |
Rep 1,269
My soft-top motor was replaced 3 months ago. The dealer did not need to remove the entire soft-top.
2019 Porsche 911 4 GTS
2016 BMW M3 2008 BMW Z4M coupe |
04-19-2008, 07:57 AM | #6 |
Rep 367
I would like to see how they did that. The whole hydraulic unit is in the left rear, at the very bottom of the top
