09-27-2021, 05:14 PM | #1 |
sportscars only
3245
Rep 3,198
LHD vs RHD - which is better?
I always joke that we drive on the RIGHT side of the road, meaning others actually drive on the wrong (left) side haha. Obviously, that's not the case.
However, I do wonder if there is really a better side, and I guess the criterion would be to curry to the majority of ppl who are right-handed (unless you think there is are better factors), so is there and if so which is the better side?
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
09-27-2021, 05:24 PM | #2 |
Rep 166
There’s no material difference other than if you had a manual transmission, as many in the UK do, then it’s a matter of preference whether you steer with your left hand while shifting with your right hand or steer with the right and shift with the left.
Personally I prefer the 1-2 shift with my right hand since the shift pattern is the same regardless of RHD or LHD. |
09-27-2021, 05:29 PM | #4 |
Rep 5,484
Drives: 23 X7 40i; 23 M3; 24 cooper s
How about center drive
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
vreihen1615283.00 Murf99314114.00 infinitekidM2C4206.50 unluky7528.00 Noneya251.50 MKSixer34184.50 dreamingat30fps5330.00 M5Rick60091.50 |
09-27-2021, 05:30 PM | #5 |
Rep 15,858
09-27-2021, 05:33 PM | #6 | |
sportscars only
3245
Rep 3,198
09-27-2021, 05:34 PM | #7 | |
sportscars only
3245
Rep 3,198
09-27-2021, 05:38 PM | #8 |
sportscars only
3245
Rep 3,198
Very true, but that's kinda a different issue.
09-27-2021, 05:39 PM | #9 |
Rep 3,049
Depends on which side of the road your Country uses.
bobowar1353479.00 ///mawana80.00 |
09-27-2021, 05:43 PM | #10 |
sportscars only
3245
Rep 3,198
Maybe my OP should've been worded better, my pt is trying to figure out which side is better due to how RHD and LHD cars are configured, based on the supposed criterion of right-handed ppl being the main factor.
09-27-2021, 05:51 PM | #11 | |
Rep 15,858
I know as a 'left-hander', many things I use in my life are designed for right-handers. For machines I've used/driven, you just adjust and handle it. |
09-27-2021, 06:01 PM | #12 | |
sportscars only
3245
Rep 3,198
So, just trying to figure out the OP w the premise of what should be best for right-handed ppl.
09-27-2021, 06:23 PM | #14 |
sportscars only
3245
Rep 3,198
I'd tend to agree, my man, just trying to figure out "ze why".[Merovingian]
09-27-2021, 06:59 PM | #15 |
Rep 4,165
I live in a RHD country and frequently drive in the US (LHD). Its not a big deal to switch. Just remember one simple rule - if you're looking at headlights in front of you, you're in the wrong lane. 😂
09-27-2021, 08:08 PM | #17 |
Rep 3,032
Common sense would tell me that you want your best hand on the wheel, so your right, and your left can shift or deal with the radio or what not. So RHD it is*
*maybebiased |
09-28-2021, 02:22 AM | #18 |
Rep 3,910
09-28-2021, 02:25 AM | #19 |
Rep 3,910
09-28-2021, 03:48 AM | #20 |
10859
Rep 4,893
From a drivers/ergonomic POV, regarding the transmission/shifting issue, one could look at F1 cars from the late 80's.
These cars were bespoke build for professional drivers so they could then choose what they wanted. Most cars, including cars from UK based teams for UK F1 drivers were build in LHD configuration, so right hand shifting. But I don't know if that is also the best configuration for a left handed person. From a car POV, a lot of cars are definately designed for a specific, side. You can see that very clearly for cars with an I6 enginge and RWD (so transversal layout): Cars from UK based manufacturers tend to have have the air flow management just the other way round (so inlet/exhaust on the opposite side) than EU or US based manufacturers. An I6 engine has a distinct hot and cold side. Of course you want the cold side on the side of the steering column, and on the side of the brake system (both are heat sensitive components). So opening the bonnet of, say, a TVR with I6 engine, it all looks perfectly a mirror image of say a BMW Most people don't know that So a RHD TVR with speed six is technically a better car than a LHD TVR with speed six, and a LHD E46 M3 is technically a better car than a RHD E46 M3 (the 'slant six' config also restraints the exhaust system in the RHD config with the steering column limiting space for optimal headers) And of course, from a drivers POV the place of the tacho and speedo is also important: when driving, your eyes most of the time are roughly directed to the middle of the bonnet tip. From a drivers POV the tacho is more important than the speedo (from a commuters POV maybe the other way round), so you want looking at the tacho to be the easiest/fastest move. That means the tacho should be positioned on the side of the center console and the speedo on the side of the door. Cars that have it the other way round are not truely 'drivers cars' imho and are ment to be driven speedo oriented (and maybe full auto mode...) Unless you can have a huge tacho in the middle of course, but this is an example with 2 equal dials and how to favor them.
