      05-24-2021, 10:05 AM   #23
filtercoffee
I like Coffee & Z4s.
106
Drives: 2007 Z4MC
2007 BMW Z4MC  [0.00]
Update: Downsizing from 245/40/18 to 245/35/18 solved the issues. Michelin Pilot Sport A/S 3+.
The steering now feels lighter. With the 245/40s it felt really heavy, to the point where it wasn't enjoyable to drive at low speed. Now it's more reasonable, though it still feels heavy and I'd like it to be even lighter. Additionally turn-in feels more responsive. I wonder if these effects are due to the smaller sidewall having less flex, or a change in scrub radius due to the smaller diameter wheel. /shrug. I'm enjoying the car so much more now.
I'm on 18x9 ET30 wheels, struts mounts are pushed all the way in for max negative camber.
My main lesson from this is that seemingly minor wheel/tire changes can make a big difference, and you don't really know until you try it (unless you're an automotive engineer). I guess this applies to all mods really.
      05-24-2021, 02:29 PM   #24
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
I would not call the steering in the Z4MC heavy. It's not even close to, in terms of "heaviness" when compared to my e53 X5. With that said, I didn't feel that it had made any difference (that I had noticed) when I switched from my stock 225/45/18 to the current 245/35/19 continental extreme DW. Did you change out for an underdrive power steering pump pulley by any chance?
      05-24-2021, 02:32 PM   #25
filtercoffee
106
Drives: 2007 Z4MC
Those two tire sizes are comparable in diameter. (within 0.2") so boosts credibility to the theory that wheel diameter changes can change steering effort.
No steering system mods. My wheels are ET30 though compared to stock ET42.
      05-25-2021, 07:39 AM   #26
tecnicaeleven
Drives: 07 Cooper S / 07 M Roadster
Do you think a 255/35/18 would have solved the problem? Its wider, but also shorter than the 245/40
I ask because I have the same unmounted wheels, and its about time for tires
      05-25-2021, 01:11 PM   #27
filtercoffee
106
Drives: 2007 Z4MC
tecnicaeleven I cannot guarantee.
      10-15-2021, 07:22 PM   #28
lookingforanusp
Drives: 06 Z4M Coupe
So, I'm looking for a consensus. With a properly offset 18x9 with a 255/35 in the front of a Z4M, do we experience rub during high-speed driving? Or only during parking lot (full-lock) maneuvering?
      04-24-2022, 10:06 PM   #29
filtercoffee
106
Drives: 2007 Z4MC
Back on stock suspension
245/35/18 rubs just a smidgeon on the hardest hairpin turns in autocross on the rivets.
9inch ET30.
No rubbing in regular driving or parking lot maneuvers.
wdb4732.00
      06-20-2022, 07:27 AM   #30
2285
9inch ET30.
What was final camber settings after going back to stock suspension?
      01-26-2023, 09:28 AM   #31
blufc3s
blufc3s's Avatar
Drives: 2003 Z4 3.0i
driver side front where the bumper cover meets the fender:
View post on imgur.com
that's where it rubs when I turn right. (well, used to rub)
here's the rub point when I turn left:
michelin pilot a/s 3+. probably should have stuck with 235. oh well. I hope people can learn from my mistake. and any advice is appreciated.
Mine are rubbing in the same spot. The clip that holds the bumper/fender together very near the rub spot is broken. Not sure, but suspect this rubbing may have broken it.
I currently have 225/45/17 tires on 17x7 rims 40mm offset with 20mm spacers. I just ordered 15mm spacers in the hopes this will cure it.
      01-26-2023, 11:03 AM   #32
maupineda
Drives: E86 Z4MC
Use wrong size tires and wheels and be not surprised if rubbing and screwing your liners
