03-26-2023, 05:22 PM | #1 |
Rep 59
RP Synchromax made it WORSE?
Recently swapped out the stock trans fluid for RP Synchromax to see if it would help with the 1->2 shift. This happened at the same time the car got headers and re tuned, with the power going up from 305WHP to 335WHP.
I've taken the car on several spirited drives and it seems to have made things worse. 1->2 shift is still pretty much the same but now 3->4 is awful. I missed that shift like 3 times under full load, it was just painful. I basically have a solid grip and apply constant force and then the car shifts. When I'm super deliberate about it, it seems fine but it requires way more force than before. Not sure if this is related to the tune/power bump (i don't think so). I'm guessing the best thing to do is try another trans fluid or go back to stock? |
03-26-2023, 07:14 PM | #2 |
Rep 12,565
Doubt its tune/power. Some folks swear by RP but one thing I've never heard is someone complain about the OEM stuff (i.e., MTF-LT2). Try OE fluid and see how that works out.
E93Seattle (Racerbruce)799.50 |
03-26-2023, 08:42 PM | #4 |
Rep 2,868
I have RP in mine and still does. It's much better shifting than the OE fluid for me.
03-26-2023, 10:29 PM | #5 |
Rep 59
03-26-2023, 11:19 PM | #6 |
Rep 59
Was looking at FCP and it seems theres LT-2 and LT-3? Is it LT_2 across the board for all Z4Ms?
03-26-2023, 11:35 PM | #7 |
Rep 2,868
Nope. My main reason for switching from OE was the 1-2 shift and RP definitely made that better. 3-4 shift was never an issue for me whether OE or RP.
03-27-2023, 05:39 AM | #8 |
dances with roads
4737
Rep 4,099
03-27-2023, 07:51 AM | #9 |
Rep 12,565
Weird. I swear other than the first few weeks of owning a Z where I was getting used to it, I’ve never had issues with 2nd gear in all 3 Zs I’ve owned. Granted they weren’t entirely stock (e.g. some has CDV delete, others had a ssk) but those really wouldn’t that make of an impact. I just let the clutch out a little slower for 2nd and it’s good.
03-27-2023, 08:08 AM | #10 | |
dances with roads
4737
Rep 4,099
03-27-2023, 08:29 AM | #11 | |
Rep 783
To the OP, these transmissions need a little more finesse when driving fast, you can't jam gears no matter what fluid you are running.
2008 E86 M coupe
03-27-2023, 09:58 AM | #12 | ||
Rep 59
I'm never specifically trying to jam gears but just shift quickly when I'm full throttle - When you are full throttle, what exactly should my shifting technique be for a smooth shift? |
03-27-2023, 11:31 AM | #13 | |
Rep 783
Shifting gears quickly at full throttle is a situation you'll never encounter on the street, at least not if you are driving within the law. It sounds like you are pushing it to its street car limits but expecting race car capabilities. You could also have damaged synchros and that is making shifting worse, driving it to it's limits will continue to degrade those synchos. I doubt this is a problem that is going to be solved by trans fluid alone. I think you might have to slow your shifting down a bit, a very slight pause in neutral before going to the next gear. You could also go old school and double clutch.
2008 E86 M coupe
2one3E902422.00 |
03-27-2023, 11:43 AM | #14 |
Rep 975
The issue would be less present on the Si as the powertrain assembly rotates slower, so the synchros maybe at the limit of what they can handle when shifting at redline and trying to be fast. The ///M has 1000 rpm more, and that effect is multiplied by the gear ratios. So the 1/2 synchro spins about 4000 rpm more compared to what the tranny sees in the Si variant.
03-27-2023, 08:57 PM | #15 | ||
Rep 12,565
grannyknot953.00 |
03-29-2023, 02:59 PM | #16 | |
Rep 59
03-29-2023, 06:13 PM | #18 | |
Rep 12,565
wdb4736.50 |
03-29-2023, 06:55 PM | #19 |
Rep 975
03-30-2023, 08:48 AM | #20 |
Get off my lawn
932
Rep 1,160
Similar experiences to others. I run Redline fluids (MT, diff) and ZHP knob, shift purposely but not in a rapid-fire way and no real issues. On very cold days it can be tougher until the fluids warm up.
Even on track in my M and other cars I am never frantic. Purposeful and swift, more important to get the shift and revs right than shave that .01s. |
04-17-2023, 09:19 PM | #21 | |
707
04-17-2023, 10:04 PM | #22 |
Rep 66
My first z never had the 1-2 crunch, sold it w/ over 90k miles. Ran OEM fluid.
Current z does grind on the 1-2 shift from time to time, 32k miles on her, going to fill with fresh OEM and see if that changes anything. I did run redline diff fluid FWIW, read too much conflicting info on the use of other tranny fluids to switch from OEM. |
