05-06-2019, 10:31 AM | #23 |
Rep 4,058
Hopefully this is not a dumb suggestion but if the problems persist, is there a good reputable BMW dealer in your area that could look into this for you without charging a crazy price? If you have such a dealer with a mechanic who has been wrenching on BMWs and N52s for years, he may spot the problem very quickly and save you a lot of anguish and worry.
Huz-Z
05-06-2019, 10:44 PM | #24 |
Rep 687
I might get a smoke test done too, will look into this. Thanks for your reply!
05-06-2019, 10:47 PM | #25 | |
Rep 687
The BMW shop I use has been around for ever, the owner even tried to figure it out. There is one more place to try but since I'm already at about 1,500 into this with out any improvements at all I'm getting a little gun shy. |
05-07-2019, 10:42 AM | #27 |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
^whs.... my car was running rough and head check engine light that would pop on and off and have similar symptoms to what your describing...both flaps of disa were wedge just before the valves and kind of blocking air passage
05-07-2019, 09:57 PM | #29 |
Rep 687
*UPDATE* Bought gas tonight when on the fuel light and afterwards the issue seems to be gone. Did a few hiccups right after fueling but then stopped. Drove approx 40 miles hard and didn't have a problem. Also seems to idle better. I've put about 1 1/2 tanks of fuel in it since I purchased the car. So now I'm wondering if the dealer used 87 or I managed to get a bad tank. I also put techron in the last tank before today's. Will drive a few hundred miles this weekend to make sure the issue is gone. Thanks everyone, I'll report back!
05-07-2019, 10:01 PM | #30 | |
Rep 3,004
AWESOME front lights
Racerbruce
05-08-2019, 06:46 AM | #31 | |
Rep 4,058
Keep us posted!
Huz-Z
05-08-2019, 05:16 PM | #32 |
Rep 18,785
05-08-2019, 05:38 PM | #33 | |
Rep 33
05-10-2019, 09:08 PM | #36 |
Rep 687
*UPDATE* Car is still broken. Started acting up after about 50 miles and after heavy throttle when pulling out. Also had the worst shift yet, makes a terrible wooouf sound while shifting in auto under moderate pedal. Starting to think maybe the torque converter? This is seriously driving me nuts!
05-11-2019, 05:04 PM | #37 |
Rep 4,058
Man, I feel your pain. If the independent shops aren’t fixing this, which seems to be the case, then it’s time to find a bona fide bmw dealer.
05-11-2019, 05:06 PM | #38 |
Rep 687
I think you're right. Hope it's just a coding issue and not the trans. If it is would a 6sp manual be a good swap that wouldn't totally kill the value of the car?
05-11-2019, 05:53 PM | #39 |
Rep 4,058
