      04-29-2020, 04:16 PM   #1
mziggy16
Drives: '07 Z4MC, '01 911 C4 Cabriolet
Help Troubleshooting Misfire
A few days ago I took the Z out for a mental health drive. Shortly after leaving my house the ride got rough, power was low and it threw an SES. I limped it home 1/8th a mile, turned it off then back on and the SES and rough idle were gone.
Fast forward a few days and I fired her up and gingerly drove around the block and then gradually extended my range to include highway driving and a total of about 45 minutes of trouble-free pleasure. As I was pulling in my driveway the SES and rough idle returned, so I parked it, shut it down then turned it back on and everything was okay.
The code reader tells me P0301 Cylinder 1 misfire. The google machine tells me it could be many things, but most likely the ignition coil.
I pulled the coil and plug today (images attached, sorry for the blurry one). The plug has about 3k miles on it.
My plan is to replace the cyl 1 coil.
Questions:
1. How can I tell if I have a Bosch or Delphi coil? I'd like to make sure they all match. Was OE in 2007 Bosch? I see three different options:
Delphi OE: 12138616153
Bosch OE: 0221504470
Bosch OEM: 12138616153 (same pn as Delphi)
2. With 133k miles, should I replace all 6 coils? Cyl 4 coil was replaced 50k miles ago and the rest are original.
3. Any other thoughts on troubleshooting?
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i
      04-30-2020, 11:28 AM   #2
JAS1169
Drives: BMW 2003 Z4
Exchange the coil from #1 with another cylinder. Clear the code & then do another test drive. If a new code po301 travels on the cylinder you exchange the coil with. Then you confirmed it as a bad coil.
It's recommended to do all of the coils. However, it's not the end of the world if you only replace the bad one.
Unless maker marked I wouldn't be able to determine the actual maker of a coil.
      04-30-2020, 04:32 PM   #3
wdb
dances with roads
wdb's Avatar
4722
Could be the photo but it look like there's a heap of deposits on that spark plug. Are they all like that? You might want to scope the cylinder and have a look at the piston etc.
      04-30-2020, 04:53 PM   #4
mziggy16
Interesting observation. Attached is a pic from when I changed the plugs last summer. Notice the one with the most build up? At the time, I showed it to my Indy mechanic and he didn't seem concerned.
Scoping a cylinder is beyond my abilities. Any other thoughts based on the current evidence?
      04-30-2020, 09:33 PM   #5
mziggy16
Jackpot. Swapped Cyl 1 and 2 coils today and took her for a spin: Threw a P0302 code - Cyl 2 misfire.
6 new coils on the way.
wdb4721.50
      05-01-2020, 06:15 PM   #6
JAS1169
Drives: BMW 2003 Z4
Yea, it's really a ez test, which is almost fool-proof.
*must have a scan tool to confirm error travel.
