      05-07-2018, 07:31 PM   #1
kklin
Drives: BMW Z4 M Coupe
"The key set"
I never realized that the key has a rechargeable battery - https://www.facebook.com/P1Software/...64089130469548
      05-08-2018, 12:04 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
We kinda knew this.
Swap keys the first day of the month so they both stay charged.
      05-11-2018, 08:35 PM   #3
rsutoratosu
Drives: Z4 3.0i
Theres a thread, I had a broken old sonic care tooth brush... use that to charge the key
-Roranji
      05-11-2018, 08:36 PM   #4
rsutoratosu
Drives: Z4 3.0i
i only found out you can charge it less than 30 days ago through this
-Roranji
      05-11-2018, 09:17 PM   #5
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
I bought a sonic care charger off of ebay and it didn't work....... key didn't charge at all
      05-13-2018, 10:57 AM   #6
dc_wright
dc_wright's Avatar
231
Drives: 2006 Z43.0si Roadster
But I'll bet the guy selling the Sonic tooth brush chargers has seen a big spike in sales.
Top Down 365
      05-13-2018, 03:23 PM   #7
antennahead
+1
      05-23-2018, 06:08 PM   #8
boca1
boca1's Avatar
22
Drives: 07 z4 3.0si
your key may not need a charge it may just need to be re-programmed. When I got my car it came with two keys, one worked the other didn't, was about to cut the key open to put a new battery in when I ran across this post. worked like a charm.
One word of caution, each key remembers your memory functions, so when I got the 2nd key working, the first time I used it open the doors it move my seat all the way forwards and up (must have been the wifes setting of the PO
The key is charged bye the key being in the car. I have found that carring the key in my pocket along with other crap the button get pushed be accident and there is some combination the resets the key. Try the procedures below and have both keys at the time you do it, before you go to the expense of a new key.
Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
StickMon551.50
      12-05-2018, 06:37 AM   #9
Efthreeoh
Drives: E90 & Z4 Coupe
Method 1:
Method 2:
Method 3:
Thanks for the post. Could you please clarify Method 2. You state that a working key is required to program the non-working key. Is the procedure in step 2 and 3 using the working key in the ignition sequence (i.e. is the "working key" Key 1)?
Thanks
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission.
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
