      08-08-2019, 11:30 AM   #1
ryank382
ryank382's Avatar
102
Drives: E92 M3, Z4 M Roadster
Knocking/creaking noise with chassis flex
Hi guys,
So every time the chassis becomes unsettled like when going over bumps (not from shock compression or rebound) and such there is a heavy creaking that turns into a much worse knocking or banging type noise depending on the size of the bump or how much the chassis is flexing.
My idea is this : I just moved into a house with a very messed up driveway and every time I drive into the garage it involves going over a very ridiculous small hill/bump that leaves part of the car suspending in air as I drive over it. At first it was just small creaking noises which my m3 still makes which i just figured is the chassis flexing (no big deal right?) Is it possible that this caused a crack or break in the subframe or something of that sort? Maybe something has to be torqued down? Strut mounts? idk...
Car is going to shop on monday but figured I get some ideas beforehand and ask how dangerous it is to drive a car over a messed up driveway like that. I guess if it causes enough chassis flex with consistent creaking every day in an out its a matter of time until the pressure breaks something right?
      08-08-2019, 12:14 PM   #2
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Where is the creaking coming from? Does it sound like it's from the dash?
My guess would be the strut braces needing torquing at the firewall.
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
      08-08-2019, 02:07 PM   #3
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
+1 on strut braces. They need to be at 31 or 32 ft lbs and they tend to come loose. I put blue loctite on mine as recommended by other forum members and retightened and have not experienced the knocking/creaking anymore. Another thing is to check the sway bar end links in the front. Also check the rear strut braces underneath the car, those have a tendency to strip out the threads themselves.
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
      08-09-2019, 10:29 AM   #4
ryank382
ryank382's Avatar
102
I can't pinpoint exactly where its coming from but it sounds like its coming from the front center. Will look into the strut braces thank you
awesome will look into those points thank you!
      08-09-2019, 11:00 PM   #5
gwbw
Drives: 2006 Z4MR
Strut braces for sure. I just about tore out my dash board but read this forum. Tightened the strut braces. Problem gone.
      08-10-2019, 12:35 AM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
Here's hoping you just need to tighten them.
One of mine snapped the weld.
      08-11-2019, 03:49 PM   #7
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
LOL- I did the same thing on our E92. It absolutely sounded like it was coming from the dash!
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
ryank382102.00
      08-16-2019, 06:06 PM   #8
ryank382
ryank382's Avatar
102
You guys were right it was the strut braces needing tightening thank you!
      01-29-2020, 06:05 PM   #9
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
I am getting this noise and my strut braces are very f'n tight.
No broken welds on either the strut towers or the firewall mount.
When I remove the strut braces completely the noise is gone.
So I know it has something to do with the strut braces but can find the cause.
Does anyone know what else I can try next?
