09-27-2017, 04:25 AM | #1 |
Rep 52
2007 AUX input
Hello, I would like to retrofit this in my 2006 3.0si, pictures below.
I need: 1. 2007 cover with hole for AUX-IN socket (under the A/C panel unit)#51459128397 2. AUX-IN socket #84 109237655 3. the wire #??? Can you help me finding proper OEM number for the wire? EDIT: Can this be #61129172021? Last edited by Ponta; 09-27-2017 at 04:35 AM.. Reason: I probably found |
09-27-2017, 02:01 PM | #4 |
Rep 52
Ok, thanks. I have done some research and it seems to me that the wire 61129172021 would be better, it is cheaper than 84110302893 part with socket (we pay extra for socket, which is trash after all) and I do not need other parts showed in this manual:
http://www.zroadster.com/forum/index...eitung.108562/ One side you just put into AUX-IN socket and second one with 3 pins you dismount and insert behind the radio IF the space is occupied, which IS in my case because of CD changer. Last edited by Ponta; 09-27-2017 at 02:09 PM.. |
09-27-2017, 03:17 PM | #5 |
Rep 847
Makes sense if you already have the AUX socket part. Just seems a bit over engineered, since the other cable has no socket involved, just a wire attached to a 3.5mm female plug.
