03-01-2019, 12:05 PM | #1 |
Rep 20
1970 BMW 2800 (Bavaria)
I have question regarding a 1970 BMW 2800 (Bavaria) car I'm about to go purchase in the next couple of weeks. I want your personal comments so I can decide on what I want to do with the car. The car is all original and I was informed that it was previously owned by a producer before they purchased it but I don't know from who as of now. Its been in a garage for the past 27 years so it will need to be refreshed. I'm getting a good deal on it so I think its worth putting some money in it. I will be selling it after Its road worthy and thinking about taking it to the BMW show in Fontana in May.
so do I add newer BMW parts like wheels or leave it all original? THESE ARE THE ONLY PICTURES AS OF NOW Last edited by Thomas3978; 03-01-2019 at 01:08 PM.. Reason: YEARS CORRECTION |
03-01-2019, 01:20 PM | #4 |
Rep 6,878
Drives: 2018 M2 AW DCT
Bavarians are not very much in demand. They had lots of problems. You probably won’t get your money back if you restore it. To maximize your return if you restore it, it should be restored to stock.
03-01-2019, 02:02 PM | #6 |
Rep 6,878
03-01-2019, 02:41 PM | #7 | |
Curmudgeon and Pedant
690
Rep 3,489
I would rip off the carbs and have a shop re-build them. You're going to need new tires, and all the hoses in the engine compartment. Drop and drain the fuel tank. There is quite a community (start with mye28.com and ask them for www references.) I had an E12 530i (similar in many respects.) and it was a great car. IIRC from Roundel issues and articles, a good-condition road-going Bavaria might be worth $10K. A highly-restored one might be twice that. But it's hard to get parts, and the interior is sure to be shot and that's quite a bit of money to restore. |
03-01-2019, 02:48 PM | #8 |
Rep 1,060
No way. I say around 7-10k depend on the car.
JB4 Tune, MHD backend flash, E85
VRSF 7" Intercooler, BMS OCC VRSF CP & TIAL 50mm BOV, BMP PI DocRace 6266 single turbo. |
03-01-2019, 02:56 PM | #9 |
Rep 6,878
03-01-2019, 03:00 PM | #10 |
Rep 1,060
He said he will refresh it, this could mean restoring. Also he asked to keep original or no.
03-01-2019, 03:20 PM | #11 |
Rep 3,315
Pictures provided aren't enough to judge. If the car has no rust issues, you're in business...of course that would be very rare in these cars (although they aren't nearly as bad as an E9). Even more so if the original toolkit and full interior is there and complete...the toolkits alone sell for $$.
Once you get it out of storage, assess its needs. At a minimum as suggested it will need the gas tank out (these are known to rust/leak along the seam where they mount to the trunk floor even in cars never exposed to winter roads...mine required two new tanks during its 22 years with us from new), all new fuel lines, and the carbs cleaned. If you're lucky, it's had the downdraft Weber carb replacements added as the original Zeniths are junk. You'll need to carefully prepare the engine for it's first crank attempt -- details on that you can find online. Check it for all the usual M30 issues like the oiling tube bolt that backs out in the head and deprives the lobes of oil...you know, all the basic M30 engine evaluations. It will need all four calipers rebuilt or replaced, all new soft brake lines, and probably a brake master cylinder. It will also need a new clutch master and slave cylinder most likely. Most likely all coolant hoses are junk by now and will need replacement. It wouldn't be surprising *at all* if the heater core is leaking. All fluids would need to be drained and replaced of course. The choice would be to: (1) get it road worthy and sell it; (2) sell it as is, as a barn find untouched; (3) restore the entire car. Truly restoring the car begins with numerous multiples of $10k. So the choice likely comes down to #1 or #2. Either path can be fruitful. Just document every last area of the car, fully present its condition, and then put it on BaT, no reserve.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
03-01-2019, 03:22 PM | #12 |
Rep 2,294
One could spend way more restoring this car than it would be worth.
The Bavaria model is not highly sought after, although this one appears to be a 2800 sedan, a bit more equipped car than the Bavaria (which I recall was a NAmer market car only - could be wrong about that tho). If that car has sat for 27 years, and not in great storage, it will have a LOT of things to repair/replace etc, assuming you can even get parts today. Personally, I wouldn't buy it, even for next to nothing.
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
03-01-2019, 03:51 PM | #13 |
Rep 20
the car was put away in running condition 27 years ago because his kids weren't taking care of it and he just stored it. the owner is 68 years old and now wants to clean up the garage and get rid of it. To rebuild the carbs and adjust is going to cost $500. I think I would have to spend around $1500 to just get it in good safe running order. Tires, brakes, gas tank, registration..
I just want to see how the interior is and that tool kit in the back. Last edited by Thomas3978; 03-02-2019 at 03:06 PM.. |
03-01-2019, 04:05 PM | #14 | |
Rep 6,878
03-01-2019, 04:10 PM | #15 |
Rep 440
Drives: 2013 335i xDrive
If you are interested in this car for the profit potential, your best bet would be to buy it "as is" and sell it as a barn find. Don't even wash it. Just flip it.
If you are going to fix this and that, you have a potential money pit on your hands. These things have a way of snowballing. 27 years of sitting means mice damage, deteriorated rubber, brittle wiring and frozen parts. But - and this is a big but - if you are going to do a full-blown restoration a complete, unmolested car is the best start you could possibly have.
I'm not completely useless, I can be used as a bad example.
03-01-2019, 04:25 PM | #16 |
Rep 20
thank you guys for the advise!
The owners wife had knee surgery this week, so we are going to wait until his wife gets better. When I get pictures I will post some up. |
03-01-2019, 04:42 PM | #17 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
This one went for $8,800 on Bring A Trailer and it looks pretty good.
https://bringatrailer.com/listing/1973-bmw-bavaria-4/
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
03-01-2019, 05:46 PM | #18 |
Rep 611
Drives: ‘18 M240i, Estoril Blue
We had a new one (3.0l) in '72. It was in the shop for most of its first month with issues, but after they got sorted it was a real delight, and a good-looking car. The paint crazed quickly, as was typical.
—Steve
'19 MX-5 Miata GT-S soft top Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i |
03-01-2019, 06:06 PM | #20 |
Rep 2,294
Yes, I think that was an original 2800 sedan color.......but that's a while back and I could be wrong. I did have a 1972 Bavaria in Malaga red back in the day, but didn't keep it long; BMW had better choices in the 2002 and 3.OCS area.
03-01-2019, 06:12 PM | #21 |
Rep 3,315
My immediate gut reaction is yes, it's factory paint, and it's Agave Green.
Current Stable:
