      12-04-2005, 07:16 PM   #1
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
Greater than/equal to symbol?
How do you type in the symbol greater than/equal to.....or less than/equal to on the PC keyboard.....
I've been a MAC user all my life......and I can't figure it out on the PC keyboard. Thanks.....
or the cent symbol?
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      12-04-2005, 07:24 PM   #2
ward
Drives: F
I don't know the cent symbol or greater than or equal to
I guess you could use the < or > (next to m) and highlight, and use control U to underline (that would only work in word, excell.... though not here)
      12-04-2005, 07:37 PM   #3
deutschmann59
Drives: 2006 325i
In the character map, all the symbols you'd ever need are there. Go to Start>Programs>Accessories>System Tools>Character Map. Once you've found your symbol, select it, click "select" then copy, and then CTRL+V it into your document:
      12-04-2005, 07:38 PM   #4
Enroutte
Enroutte's Avatar
172
Drives: ;D
like this... < or.. >
      12-04-2005, 08:23 PM   #5
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
ward....I almost used your strategy....thanks anyway!
sharp1183....thanks a lot....
      12-04-2005, 11:47 PM   #6
ward
Drives: F
why you gotta brag
glad that got worked out!!
      12-05-2005, 08:12 AM   #7
Compos Mentis
Compos Mentis's Avatar
Drives: Arctic 330xi
If you can remember the numbers 242 and 243, hold down the ALT key and type one of these numbers on the KEYPAD. This should work for most character sets. It's shorter if you use it a lot. The above is handy to find infrequently used symbols.
Compos Mentis
2006 330xi Arctic, black leather, aluminum.
18000 miles...
      12-05-2005, 08:18 AM   #8
Compos Mentis
I found that in several Central American countries, people remember ALT-64 to get the @, because the bootleg US windows versions have keyboard maps that don't match the latin keyboards. I had to ask where to find the @ to send an email address, and had it explained to me. CM
Compos Mentis
18000 miles...
      12-05-2005, 11:44 AM   #9
mds82
mds82's Avatar
364
Drives: 2006 325xi
Alt +0222 = Þ
Alt + 0162 = ¢
on a PC click start, Run, and type in charmap. this bring up the character map. on the bottom right you will see the keystroke and you can make almost any character you want ¥ even greek ΒΘΠ
