      06-21-2017, 11:35 PM   #1
Mar48
Mar48's Avatar
1100
Drives: '22 M3 Comp xDrive - Atlantis
Considering a change... Ground Control Coil Overs (525/650)
Bought my Z4M this past week and drove it 1100 miles home. Absolutely love the car, however I'm not thrilled with the coil-over setup. I thought it may be a issue but over the drive it made itself clear, the setup is too stiff for me. I can literally feel every single bump in the road, and occasionally feel like I catch air on big bumps. I've had a couple S2000's with coil-overs before but neither were this stiff.
I have Ground Control Coil Overs (525 front spring rate/650 rears).
I'm considering switching coil-over setups or maybe even going back to a stock setup with lowering springs. I want a lowered car, but since I daily drive the car and the roads here aren't the greatest, I want something more comfortable.
Any suggestions?
      06-22-2017, 11:07 AM   #2
CTMP4me
Drives: '08 Z4MC, '71 240Z with S54
Any suggestions?
Give Shaikh at Fat Cat Motorsports a call.
My FCM setup rides much better than stock and generates more grip too (336 / 616 lbs/in F/R spring rates, custom valved non-adjustable Bilstein-based dampers).
Stock suspension is comparatively harsh as well, in part due to being overdamped in rebound. The real fix for this is to get dampers with better valving.
      06-22-2017, 09:43 PM   #3
Mar48
Mar48's Avatar
1100
Thanks for the suggestion - I don't mind a lightly harsh ride as I'm used to driving sports cars with stiffer suspensions, when I test drove a Z4MR the ride felt perfect stock (to me).
I think my spring rates 525/650 are a bit stiff
Interested in getting some more opinions
      06-23-2017, 04:57 PM   #4
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Too stiff for street and probably a bumpy track!
I'm not sure what the Konis can accommodate as far as lower spring rates. Maybe 450/550 or even a bit lower.
If you want to try and use the GC, I'd give GC a call. Jay (owner) or one of the staff can probably help answer questions and let you know what can/cannot be done.
If you're looking at other options search Fortune here on the forum. There are some nice setups there with digressive pistons yet street oriented.
      06-24-2017, 09:55 PM   #5
Mar48
Mar48's Avatar
1100
What do you mean by Koni's? I may be misunderstanding your response, I have GC coilovers on with 525/650 spring rates and find it too stiff/bone rattling so I'm considering all other options. Would OEM shocks with lowering springs (like H&R) ride a little "softer"?
      06-25-2017, 07:52 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
GC use Koni dampers.
      06-25-2017, 02:36 PM   #7
Mar48
Mar48's Avatar
1100
I was wondering that but couldn't find more info on a quick search. thanks!
      07-02-2017, 04:08 AM   #8
Finnegan
Finnegan's Avatar
Ian nailed it.
My idea was to see if you could just swap out for lower spring rates but keep the rest of the GC coils. GC would know what the Koni valving could accommodate. This should be cheaper than other options and certainly better than (potentially tired) stock dampers plus lowering springs.
      07-02-2017, 08:27 PM   #9
Mar48
Mar48's Avatar
1100
Sure - I reached out to Jay and got some ideas from him to try to make the current setup a little more daily driver friendly. If that doesn't work I'll see what he says about lower spring rates
Thanks!
      07-09-2017, 06:36 PM   #10
3002 tii
3002 tii's Avatar
2288
I run 450/550 on Koni DA and find the ride to be really civil. It also helps I'm running meaty 17's.
Follow for latest mods
      08-03-2017, 04:00 PM   #11
Beedub
i run club sports and they feel so good, stiffer thanks stock but imo a much better ride , feels really well damped, the KW uses a really nice damper design.
      08-04-2017, 10:43 AM   #12
Manxman1950
Drives: Z4M roadster
I just changed to KW V3s, from stock dampers with H&R lowered springs. The ride is now much more controlled and far less "crashy" over potholes and sharp bumps. The KWs are German made, stainless steel and TUV approved and are fully adjustable. I sourced them from a UK supplier, who is currently offering a £300 discount, making them very good value IMO.
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
      08-04-2017, 01:54 PM   #13
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Ian nailed it.
That's the way to go! I have 500/600 springs. I'm sure GC could rework the springs and valving to be more civilized for daily use.
2006 Z4MC - #LL93158
