      09-19-2019, 08:44 PM   #111
eggman51
Drives: 2006 BMW Z4 M Roadster
Received mine - looks great! Will be a bit before I get to installing it, so any "DIYs" that emerge will be helpful for the mechanically challanged twits like myself.
      09-20-2019, 12:16 PM   #112
Westersund
Westersund's Avatar
Sweden
132
Drives: BMW Collector
Originally Posted by F360C View Post
Oh this means we must be getting close to my spot on the production list!
Yes sir!
BMW 520dAT M-Sport -12, BMW Z4 M Coupe -06, BMW Z3 Coupe -99, BMW 740i/6 -96, BMW M5 3.8 -92 and BMW M535i -87.
      09-22-2019, 11:58 AM   #113
Westersund
Westersund's Avatar
Sweden
132
I'll let MOTK post pictures himself, but he has installed the kit now.
wdb1730.50
      09-24-2019, 04:02 AM   #114
Westersund
Westersund's Avatar
Sweden
132
Update time! 2 Kits of ducts are done, however the laser cutter have deadlines to meet this week so my parts aren't prioritized. They would be done by next week, sorry about the delay but it's out of my hands. We will continue printing ducts though to keep up.
We've also made a switch from ASA plastic to PET-G plastic for the front bumper ducts. PET-G is a little pricier (won't affect the price though), a little shinier but with more stable characteristics. The reason for the change is the issues with warping with the ASA, the PET-G turned out great with no warping at all so we're sticking with it (pun intended).
wdb1730.50
      09-24-2019, 07:06 AM   #115
MOTK
Drives: Z4MC
Indeed finally Haven't had a lot of time recently.
After a couple of "brain fart" moments by both of us the install went quite smoothly. I found what I thought to be good routing option for the hose with just a small amount of cutting required to the lower corner plastic.
Hose length required is about 1.2m per side and the routing provided at least 5mm clearance on full lock with my 235/40 8.5j et 38.
I was unable to use the top to mounting holes of the funnel with my 355x32mm discs as the button head bolts fouled the disc, I am going to try some countersunk bolts to see if they provide enough clearance.
Word of warning, the bumper vents are slightly fragile so don't be an oaf like me and crack one I've taped it up and I think it should hold, I've a trackday at the nurburgring in a couple of weeks which should be a good test for them!
MC IB, CSL intake, Schrick 288/280 cams, SS race bbox, RPI, AP f&r w/RSL-29, Apex ARC-8, A048, KW CS, Turner arms & RTAB limiters, VT engine mounts, Rogue pulleys & RSMs, Tillett B6s, custom half cage, UUC ssk, M5 knob, oem strutbrace
wdb1730.50
Vanne955.50
      09-24-2019, 05:27 PM   #116
wdb
dances with roads
wdb's Avatar
Drives: '07 Z4MC, '07 E93 328i
Wow! Thanks for the updates and pictures of installation. Hopefully you can include one after the bumper cover is installed, so we can get an idea of the look from outside?
      09-25-2019, 04:14 AM   #117
Westersund
Westersund's Avatar
Sweden
132
wdb1730.50
      09-25-2019, 04:03 PM   #118
MOTK
Drives: Z4MC
Thanks Andre. Yeah sorry I didn't think to include one really as it looks pretty much stock if looking from it at any kind of normal angle. If you happen to have your head on the ground and look up you will see that it does not quite fit like the factory vent but personally that is not an issue for me.
wdb1730.50
      09-26-2019, 03:19 AM   #119
Westersund
Westersund's Avatar
Sweden
132
I did a duct at first that fit just like stock, but the duct is curved in the front and this makes it difficult to print. Consider all the problems we've had with this duct, imagine if we would have stuck with the first design with the curved design.
So this design has a straight design so it has to be a little bigger to fit closely to the bumper, downside is as you said you can see it if you crawl on the ground and look up. But I felt it was the best way to go in the end.
      09-26-2019, 03:27 AM   #120
Westersund
Westersund's Avatar
Sweden
132
MOTK made me aware that there's an OE block off cover for the wheel arches (From the 3.0 Z4) you can buy for cheap. However I will still include the block off plate if you want it. The OE one in plastic cost around 5-6$ each side.
Part number 5 in this URL:
http://bmwfans.info/parts-catalog/E8...ch_trim_front/
Part numbers are:
51717056403
51717056404
      10-01-2019, 11:28 AM   #121
Westersund
Westersund's Avatar
Sweden
132
Barry's second duct is soon done and I'll visit the laser cutters tomorrow after work. If my metal parts are done I will be sending 4 kits on thursday when I'm off work.
      10-01-2019, 10:18 PM   #122
Barryb97
Drives: 2006 M coupe
Yeah!
CDV delete, clutch stop, BMW pedals, Strongstrut bar, rad hole cover, M3 reps, roundel under hood, Intravee II, Homelink, air bag sticker delete, first aid storage, keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings front, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler
      10-03-2019, 09:40 AM   #123
Westersund
Westersund's Avatar
Sweden
132
Sending Booker's and Sliktop's kits in 30 minutes. I wanted to try the epoxy resin on a scrap piece of the new PET-G material to avoid any trouble, so Barry's and Finnegan's kits will be done during the weekend.
      10-04-2019, 11:35 AM   #124
MOTK
Drives: Z4MC
Just as a small update, I ran the car for the first time in anger down my local tortuous road route, lots of fairly difficult tarmac/bumps etc. Kit performed great in that nothing fell off the backing plates do not rub at all on my 32mm wide disc on full lock and the hose routing works really well too, no rubbing there either upon inspection afterwards.
Nurburgring in a week which will be a good test and then I hope to get back to my local track before the year is out to do some 'scientific' analysis of disc temp reduction. Previously I had measured them at around 600c there which is on the hot side contributing no doubt to my premature disc failures I have suffered over the last few years.
Enjoy guys
wdb1730.50
      10-04-2019, 11:50 AM   #125
Westersund
Westersund's Avatar
Sweden
132
Enjoy guys
Great to hear! Curious to hear how it will perform at the ring and a nice touch with the temperature readings, look forward to those!
      10-09-2019, 10:22 AM   #126
Westersund
Westersund's Avatar
Sweden
132
Big shipment sent out today to Finnegan, BarryB, WDB and Eggman (revised backing plates). Enjoy!
wdb1730.50
      10-09-2019, 12:04 PM   #127
wdb
dances with roads
wdb's Avatar
Woohoo! Not sure when I'll get around to making full use of them but it will be great to have them in hand.
      10-14-2019, 02:27 PM   #128
Sliktop
Drives: 07 Z4 M Coupe
Received parts, they look great! Packing was good. Install pics coming soon. I might mix match some pieces with the E46 M3 kit i have from Hard Motorsport, we'll see... Thanks again Andre, Impressive work!
      10-16-2019, 09:44 AM   #129
Westersund
Westersund's Avatar
Sweden
132
You're welcome! Looking forward to the install pics.
      10-16-2019, 12:15 PM   #130
MOTK
Drives: Z4MC
Worked well, hit an indicated 170mph ish down the Döttinger Höhe straight and even my broken (by myself) lhs duct held up well.
With the amount of autumn leaves around the grills probably helped not having those go into the disc, fair few collected.
Some very minor rubbing noises were heard in various areas of the track, I've yet to investigate as I had to leave the car pretty quickly on my return to the uk. Nothing serious though, I ended up tie wrapping the hoses to the arb (swaybar), I expect on full droop/load is where this is occurring. That said it could be from the new A048 tyres I'm running and not the kit/hose at all.
I'm at a more technical track on monday (the ring is perhaps surprisingly not that hard on the brakes, even for an amateur like me over-using them) , just need to grab the temp paint for the discs off my mate for some readings.
wdb1730.50
      11-04-2019, 04:02 AM   #131
Westersund
Westersund's Avatar
Sweden
132
All kits ordered have been sent out now, please keep me updated guys and give me some feedback. Thank you!
      11-08-2019, 04:23 PM   #132
wdb
dances with roads
wdb's Avatar
FINALLY received my kit, through no fault of Westersund . US Postal service did its best to keep the kit at an office less than 10 miles from my house for 3 weeks, before finally somehow managing to get them to the correct local office for delivery. Parts look great! I'm stoked.
