      12-10-2018, 12:04 AM   #199
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Originally Posted by jimmyfloyd View Post
Thanks. Are there any models currently recommended for cameras or NVR? Do they make a bullet camera with zoom?
Take a look at LTS. They should have a catalog in the form of a PDF. All Hikvision cameras but flashed with their own firmware. Lots of bullet zoom options.
NVR will depend on how many cameras you are pushing, what their resolution and framerates are etc.
      12-10-2018, 12:06 AM   #200
P1
P1's Avatar
11572
Originally Posted by djsaad1 View Post
There is no doubt NVR is the easiest, but I would recommend looking into blue iris. I love it, it can do a good amount more than your typical camera manufacture software, and you can mix/match cameras with it. For example I have my two Doorbell (doorbird) cameras running on it with all the hikvision cameras.
Agree. NVR is easy, but the beauty lies in the software. Blue Iris is recommended by many...
What cameras did you end up with?
      12-10-2018, 11:48 AM   #201
dsad1
Drives: car
Hikvision DS-2CD4535FWD-IZH 3MP which I really like.
I also have a Hikvision DS-2CD6D54FWD, which I don't recommend. Too big, and need to use hikvision software to get full functionality.
I use the hikvision cubes for indoors and doorbird d101's for the doorbells.
P111572.00
      01-11-2019, 09:09 PM   #202
P1
P1's Avatar
11572
Slowly upgrading to 6MP cameras. I actually lost my 3MP turret front door camera the other day, and it was my own fault: I recently had liberally and extensively hosed down the ceiling of my front porch, and water must have gotten into the camera. Still turns on, but condensation in the lens. Perfect excuse to upgrade!
This is my second H.265 camera. On H.264 I'm seeing roughly 130 B/sec, but the second I switch to H.265, that drops to 40 B/sec. Impressive compression.
Went for this one:
I'm still waiting for the wire intake box to arrive, but once she's properly installed, I'll take some pictures.
dsad11211.50
      01-11-2019, 09:10 PM   #203
dsad1
Drives: car
Are you recording 24/7?
      01-11-2019, 09:12 PM   #204
P1
P1's Avatar
11572
Yes, all my cameras will retain a few FULL days worth of footage and then motion only for the remainder.
      01-11-2019, 11:10 PM   #205
zx10guy
Drives: 2013 135i
Went for this one:
You're going back to Hikvision and not buying the LTS equivalent?
Originally Posted by Lups View Post
We might not be in an agreement on Trump, but I'll be the first penis chaser here to say I'll rather take it up in the ass than to argue with you on this.
      01-12-2019, 12:29 AM   #206
P1
P1's Avatar
11572
No, sorry. Definitely purchased from LTS. Just had trouble grabbing a pic from their website so used a Hikvision equivalent.
zx10guy5149.50
      01-17-2019, 09:13 PM   #207
P1
P1's Avatar
11572
Camera installed and up and running. Quality of a 6MP camera is impressive to say the least. It's dark, so I am only testing in IR mode, and although I still need to make some adjustments to the camera angle, I'm noticing some softness around the edges. I'll see if it's only noticeable in IR mode. Could be a dirty dome. Will check tomorrow when it's light outside.
Some install pics:
Junction box installed.
Much more discrete than before.
dsad11211.50
zx10guy5149.50
      01-17-2019, 09:28 PM   #208
P1
P1's Avatar
11572
Just checked footage from where I had temporarily installed the camera previously. Zero softness when IR on. Must be a bad touch between lens and cover. Or smudges from me installing it.
zx10guy5149.50
      01-17-2019, 09:52 PM   #209
dsad1
Drives: car
I must not appreciate quality enough, or my eyes are just bad. All my cameras are 3MP, but I lower them to 1080p to save disk space. I really can't tell much of a difference.
      01-17-2019, 10:50 PM   #210
P1
P1's Avatar
11572
This particular location had a 3MP previously. The quality difference is very, very noticeable compared to this 6MP.
I’ll post some 3MP vs 6MP screenshots tomorrow.
      01-18-2019, 02:12 PM   #211
P1
P1's Avatar
11572
djsaad1 can you spot the difference?
3MP:
6MP:
dsad11211.50
zx10guy5149.50
      01-18-2019, 08:54 PM   #212
dsad1
Drives: car
Yes, that's a big difference. I will take a look at mine in the morning.
P111572.00
      01-18-2019, 09:00 PM   #213
zx10guy
Drives: 2013 135i
P1et,
Any reason why you chose that dome camera? I'm thinking about going with these:
http://www.ltsecurityinc.com/ip-came...ip3362w-m.html
To replace the 3MP Hikvision turrets I already have installed. And what lens is your camera? 2.8, 4, or 6?
P111572.00
      01-18-2019, 09:07 PM   #214
dsad1
Drives: car
What's the difference in the lts firmware?
P111572.00
      01-18-2019, 09:11 PM   #215
P1
P1's Avatar
11572
P1et,
I wanted a slightly smaller footprint. The camera, including the junction box, was a bit too "in your face" when people approached my house. And I have the 2.8mm lens. Frankly, all of mine apart from two are 2.8mm.
zx10guy5149.50
      01-18-2019, 09:20 PM   #216
P1
P1's Avatar
11572
The biggest thing is that it's supported. Many of the Hikvision cameras bought via Amazon or Aliexpress have dodgy firmware that can be hit or miss. LTS cameras are configured to be plug and play, and their own firmware is updated much more frequently. Plus the cameras are backed by a 3-year warranty. I've had one camera go out on me, and after a quick remote diagnosis, was essentially given credit to pick whatever new camera I wanted. I have a rep that I can email directly and he responds fast. Awesome company, and they now have monthly specials also.
dsad11211.50
zx10guy5149.50
      01-18-2019, 09:22 PM   #217
zx10guy
Drives: 2013 135i
I was afraid of any image distortion/stretch from the wider view of a 2.8mm. But from your pics, it doesn't seem bad at all. I might change my mind about getting 2.8mm cameras as I've been opting for 4mm.
      01-18-2019, 09:27 PM   #218
zx10guy
Drives: 2013 135i
Are you still dealing with Frankie?
      01-18-2019, 09:28 PM   #219
dsad1
Drives: car
Do they still have the smart features like line crossing detection, scene change, etc...? I use blue iris for motion either way, but just curious.
      01-18-2019, 09:41 PM   #220
P1
P1's Avatar
11572
I suppose it's all about what you're trying to monitor. One of my 4mm cameras is mounted right underneath the gutters, and looks at a rear door. A 2.8mm would have been to wide for that purpose...
