      05-17-2009, 08:43 PM   #1
BMW Maniac
Drives: Former Z4M coupe owner
One touch to close driver window
Mine does not work anymore....I had the battery replaced, is there a way to reset this feature like on my 97 M3? Holding the button up after the window rolls up did nothing....
1999 /// M3 Convertible Techno Violet
      05-17-2009, 10:37 PM   #2
TopDown
TopDown's Avatar
Drives: 2017 G30 540i M Sport
Yes, after your battery has been disconnected, you reprogram the window by holding the up button until the window hits the top stop, then you continue holding the button for about 5 seconds after that. Bring the window down and give it a test. If it doesn't work the firs time, then repeat the procedure.
Mine
G30 540i M Sport
Hers F36 440i Gran Coupe
      05-18-2009, 06:47 AM   #3
BMW Maniac
Does the car have to be on? I just turned on the accessories and I held it up/held it down for over 10 seconds. In the manual, it said 2 seconds were only necessary and it still doesn't work. Also, do the windows raise when you keep the key in the door lock turned for an extended period? I'm wondering if I need to have these features reset by the dealer....
      05-18-2009, 07:31 AM   #4
epbrown
epbrown's Avatar
Yep, you windows should go up or down if you hold the key in the lock or unlock position for 3 seconds or more. The car shouldn't need to be running for the on-touch feature to work, either.
I suggest taking the car to the dealer. You won't need to schedule it in or have them fix anything - in my experience, everything starts working again as soon as you get there.
      05-18-2009, 11:00 AM   #5
BMW Maniac
Haha.....I'm sure it will take them 20 minutes to just reprogram the features or something. I was first thinking of checking the fuses, but I figure the window wouldn't go up or down if that were the case.
      05-18-2009, 11:12 AM   #6
Crimson92
Smiling Politely
Crimson92's Avatar
Drives: Like a boss
the windows lost synch...just do what was said above to fix it
Some people are like slinkies...not really good for much but you can't help but smile when you see one tumble down the stairs"
      05-20-2009, 10:07 PM   #7
BMW Maniac
I've tried countless times to get the one touch feature back.....I've closed the window and held the switch more than 2 seconds, lowered the window and held the switch down for more than 2 seconds....what am I doing wrong here? I've repeated these steps countless times with no luck....
      05-22-2009, 12:25 PM   #8
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
I found with my car that I needed to have the car running for some reason to get the one-touch reset to take.
