      06-02-2009, 02:34 PM   #1
SlikM
SlikM's Avatar
Drives: '08 BSM/Blk M Coupe
where to get the rear center brake light
ok so for some reason the rear center brake light on my 2008 Z4 ROADSTER cracked. nothing around the light on the trunk is damaged, just somehow the light cracked. I thought BMW might cover under warranty but they wont and want $300 to replace it.
Anyone know where i can get one. The one i have is red but i have seen some people with a clear one, i dont care which one it is, new or used.
thanks guys
      06-02-2009, 04:57 PM   #2
chewie
Drives: 2003 Z4 2.5
LeatherZ sells one
http://leatherz.com/Merchant5/mercha...=Z4_Appearance
      06-02-2009, 05:33 PM   #3
03BeastCharmer
03BeastCharmer's Avatar
257
Drives: '13 M3
Originally Posted by chewie View Post
I think the coupe/roadster lights are different part numbers as I know some of the coupe owners wanted the roadster clean version, and were not successful.
For $300 were they trying to sell a full light assembly? That seems really high for just the lense.
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      06-02-2009, 06:01 PM   #4
nlink720
Drives: 2004 BMW Z4 Roadster
I just ordered one yesterday.
There is a red one and a clear one.. you choose.
I have ordered many things from Tischer BMW.
Check them out on www.getbmwparts.com
The part numbers are
63256917378 RED
63256930246 CLEAR
Take a look.. type in the part numbers.. the clear is slightly cheaper somewhere around $68 and the red is about $75.
You may want to get the new springs and washers too since they were redesigned to prevent the cracking since it was caused by too much spring pressure.
Good Luck.. It takes 10 minutes to swap out. Write if you need any assistance.
FS: Leather Recaro Pole Position Seats & Hardware
      06-02-2009, 07:10 PM   #5
Starscream
Starscream's Avatar
63256917378 RED
63256930246 CLEAR
He has a coupe, Those part numbers are for a roadster,
Also BMW will replace this light under warranty,
Its a known issue with the roadsters and I have had one replaced,
Best bet, Either go to another dealer or call BMW customer service and complain that your selected dealer wont replace something under warranty
Imola Red Roadster
      06-03-2009, 02:03 AM   #6
OH FO SHO
OH FO SHO's Avatar
15
Drives: z4
there is a service bulletin re: the center brake light cracking. Your dealer should replace it under warrenty since its an '08.
its on one of the forums... ill see if i can find it for you
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers
-*MY PICTURE THREAD*-
      06-03-2009, 02:27 AM   #7
bananana
bananana's Avatar
Drives: '05 Z4 2.5i, '07 323i
had mine replaced under warranty no problem..
      06-03-2009, 03:23 AM   #8
OH FO SHO
OH FO SHO's Avatar
15
Drives: z4
from robbietoo @ bimmerfest:
http://www.z4-forum.com/howto/brakelight.pdf
