07-12-2022, 02:23 PM | #353 | |
Rep 19,839
There is no park brake and he seemed confused why he couldn't put it in gear but he can't with engine and hydraulics off and wasted time stabbing the brake, the marshal realising this held onto a wheel so he could get out without losing his balance then applying the extinguisher which actually he did everything perfect on his own. |
07-12-2022, 02:43 PM | #354 | |
Moderator
29694
Rep 13,139
https://www.youtube.com/shorts/Nw51hZDaZYE
///M is art ↔ Artemis
07-12-2022, 02:49 PM | #355 | |
Rep 3,622
07-12-2022, 02:54 PM | #356 | |
Moderator
29694
Rep 13,139
(https://www.formula1.com/en/latest/a...XmRjwHBSE.html). Possibly Ferrari will detune their engines a notch for reliability reasons. Mattia Binotto:
07-12-2022, 02:56 PM | #357 | |
Rep 2,064
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d |
///M Power-Belgium64243.50 NYG10913.50 |
07-12-2022, 03:05 PM | #358 | |
Rep 19,839
07-12-2022, 03:28 PM | #359 | |
Moderator
29694
Rep 13,139
"Binotto says 2022 Ferrari ‘Superfast’ PU has a lot of innovation 2 January 2022 | https://www.grandprix247.com/2022/01...of-innovation/ With the Formula 1 engine freeze of 2022 six months away, Ferrari boss Mattia Binotto is confident that they have made a breakthrough with their Power Unit in 2021 and promises more performance to be unleashed in 2022. Winless since Sebastian Vettel triumphed at the 2019 Singapore Grand Prix, but since then the German was dismissed from Maranello and found refuge at Silverstone-based Aston Martin. Also disappearing – after an incredible spell in 2019 in which Charles Leclerc added two victories that season – was the performance when the Italian team was nabbed apparently breaking the rules. A secret deal with the FIA brought the PU into check, but it was never the same again. 2020 was a toil for F1’s most successful team fallen on hard times. They finished sixth in the constructors’ championship that year. But 2021 was better, and in fact, got better and better with every race, so much so Leclerc and Carlos Sainz managed to secure third in the 2021 F1 constructors’ title race, overcoming a similarly resurgent McLaren team. Their great rivals are also on the up, both grand teams eager to again challenge for F1 world championships at the highest level. Thus this past season Ferrari focussed all energy on developing the PU since the start of the season, with an eye on 2022. Chassis and aero, the last of this rules generation were mostly ignored to allow maximum focus on developing the ‘Superfast’ engine package. Binotto: I think we’ve made a big step in PU Speaking to Motorsport-Magazin, Binotto explained the change of the backroom strategy: “Originally it was our intention to use this power unit, which we are developing for 2022, in the last races of the season, for example in the last three races. But after the summer break, much earlier than expected, Ferrari began work on the new engine bolted to the SF21 and, according to Binotto, this was an important factor: “I think we’ve made a big step in PU. “Because if you compare it to the past, in 2020 the Power Unit was our big weakness and we were a long way behind. If you look at where we are today, then the developments are obvious.” Indeed, the newfound power allowed Ferrari to gain the upper hand over McLaren in the latter half of the season. While the British team scored a famous one-two, painfully on Red home soil – at Monza – the Italian team was more reliable, but in the end, they saw off the challenge to take third. Binotto reflected on the upsurge in fortunes: “The fact that we manage to do this, eight races before the end, was a great achievement by the team, which felt the pressure working as hard as it could to introduce the engine as early as possible.” Binotto: I’m pretty sure that we can make further improvements In what will be music to Tifosi ears, there is still more to come from the package in the months remaining to develop before the freeze, Binotto added: “I’m pretty sure that we can make further improvements. And the Ferrari team principal promised: “What I can say about the 2022 Power Unit is: Believe me, there is a lot of innovation in it.” ScuderiaFans shed light on the situation: “The Maranello team’s engineers have decided to enter the new era of F1 with a power unit that will be very innovative: beyond the architecture of the supercharging system that will see the separation of turbine and compressor, following a concept well tested by Mercedes during the hybrid years. “There is the ambition to introduce the compressor inside the intake box, with an unprecedented configuration of the upper part of the endothermic 6-cylinder that will also greatly favour aerodynamics. “The group of technicians headed by Wolf Zimmermann who deals with advanced solutions, has also studied a version that has been defined as ‘Superfast’ because it will adopt a combustion chamber capable of ensuring a phase of explosion with very fast ignition times, getting closer and closer to the principles known in diesel engines, without arriving at the HCCI solution that could easily do without the spark plug to ignite the spark. “With the ‘Superfast’ engine, Ferrari should improve combustion thanks to turbulent motions that can positively influence the speed of flame propagation, giving more homogeneity to the air-petrol mixture and to the combustion phase.” In reality, bench tests carried out so far on ‘Superfast’ have given discordant results both in terms of performance and reliability “In Maranello, they are convinced that the solution is right for the future, but the time available for development is not much and we must not take risks if the 2022 unit will have to undergo a freeze without the possibility of development until 2024. “It is for this reason that Enrico Gualtieri, head of engine engineers, would have decided to keep the innovation in the upper part of the engine (the compressor in the intake box), but to launch a more traditional combustion chamber that starts from the solutions developed to date. “As the bench tests are limited by regulation, there will be time until June to carry out the two combustion chamber options in parallel, but the definitive configuration will have to be chosen by the beginning of the summer. “The feeling is that the version of the 6-cylinder ‘Superfast’ can be put in a drawer even for the turn that the rules are taking.” Formula 1 needs a strong Ferrari sooner rather than later The Scuderia Fans report continues: “Ferrari has always been at the forefront of launching innovative ideas in F1, but the ambitions of the technicians must be recalibrated according to the moment conditioned by the effects of the Covid pandemic that have imposed very heavy constraints on the design imagination. “Having a revolutionary power unit that fails to be completed in time for next year is a risk that they cannot afford to take in Maranello. It’s right, therefore, to have foreseen a parachute.” While F1 wallows in newfound energy and popularity thanks to an epic 2021 season between newly crowned F1 World Champion Max Verstappen and defeated Lewis Hamilton, the reality is with Ferrari in the mix that audience would receive a massive boost. With the new rules package intent on narrowing the gap between the ‘Haves’ and the ‘Have Nots’ which Ferrari, under Binotto, are expected to be players again. F1 needs a strong Ferrari, a winning Ferrari, sooner rather than later. Hopefully ‘Superfast’ does the business this forthcoming season."
07-12-2022, 03:46 PM | #360 | |
Rep 19,839
They have a problem. |
07-12-2022, 04:02 PM | #361 |
Rep 24,863
Positive my friend . But actually they have a 'BIG problem with the FIA engine freeze regulation .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
07-12-2022, 04:10 PM | #362 |
Rep 19,839
If MAG was having a problem as he said with his de-tuned PU (compared to red Ferrari's ones) then for sure as you say it's a big problem for them with the approaching PU freeze.
07-12-2022, 04:31 PM | #363 | |
Rep 24,863
So ...It looked (suddenly) like the resurrection of the HAAS car . And Mick was also there with his Ferrari PU... IMHO. Ferrari won't say it to us ,if they pulled more ponies from that PU . And actually It's really necessary if they want beat MAX before It's too late . In other words : BINO knows that the clock is ticking . With still 11 races to go I fear the worst for Ferrari , because I'm pretty sure Ferrari is playing Russian Roulette ! Don't get me wrong , don't want to see them blow . I just don't want that MAX wins his second WDC title by blown Ferrari engines ... On the other hand : MAX got 2 DNF's as well . One thing is for sure : That '22 Ferrari superfast engine is fast . Very fast and actually they are having a WDC car .
07-12-2022, 04:49 PM | #364 | |
Rep 19,839
07-12-2022, 05:38 PM | #365 |
Rep 24,863
This should be your wallpaper my friend !
07-12-2022, 07:30 PM | #366 |
Rep 24,863
BINO has spoken ..
07-12-2022, 08:23 PM | #367 |
Moderator
29694
Rep 13,139
Amazing: professional photographer explains and shows how he managed, rather by chance, to photograph the Sainz fire accident sequence.
Lucky escape for Sainz:
07-13-2022, 03:13 AM | #368 |
Rep 19,839
Analysts Brundle and Palmer must have been having too much beer also with their latest comments.
Palmer saying that Russell didn't deserve the paltry 5 second penalty for punting Perez off agreeing that Checo gave him plenty of room on the outside! Brundle said Leclerc should have kept quiet about his throttle as RB would know about it... a sticking throttle. Both of them are talking absolute cock with their banter. |
07-13-2022, 03:14 AM | #369 | |
i'm just saying
5764
Rep 2,634
remember Spa's old bus stop chicane.. they were jumping through the chicane cutting white lines.. for many years.. if there is a curb you use it while racing.. problem starts when you keep seeing almost all the grid getting warnings and penalties.. cars are heavy, competition is high and cars are pretty fast.. why dont we see such penalties on the last corner of Melbourne for example.. yes there is a wall there.. it doesnt have to be that way.. just putting smaller curbs and then a run off area can take away this drama.. for tennis part.. i see what you mean but in tennis lines are straight or in football.. on track and corners lines are not always paralel + track itself can get wider and tighter according the track.. and actually we dont see such problems with sharp 90 degree corners.. because things are less dramatic in that setup.. i agree it should be clear-cut rules or setups on track.. but judging from cameras to see if one wheel is on still on the line is causing such ridiculous moments like in A1.. and seeing things only from one side is not the right solution.. on track you push all the way.. and the track itself should set boundaries.. not drivers imagination where car ll be on the exit.. actually such problems started to occur after cars getting much faster and new generations tracks or updated ones.. and if there is a multiple layouts on a track and if that corner overlaps with other ones straight we see much wider abuse.. but i cant fully blame drivers..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
07-13-2022, 04:39 AM | #370 | |
Moderator
29694
Rep 13,139
OK, no oncoming traffic on race circuits. But the point is, if you need to negotiate a corner, you must adapt your speed to stay on track - it ain't an option, it's mandatory. Same on a mountain pass: mismanage self-restraint and/or miscalculate speed in a turn and you either end up against the mountain wall or go airborne. It's as simple as that. Same with a pilot performing a looping at low altitude: miscalculate height and speed, and you'll hit the ground. No escape possible, except for pulling the ejection handle. The weight of the F1 car is no excuse. F1 drivers are supposed to know the dynamics of their cars - it's their job. The thing is, F1 drivers deliberately violate track limits to gain a speed advantage. It's cheating by expanding the ideal race line. If all other drivers respect the track limits, a violator will gain an advantage by using more space when negotiating a turn: higher speed on turn-in, higher speed going through the turn and accelerating quicker on turn-out. And using a fraction less brakes. It's unfair. The thing is, there is the common reasoning: "Hey, if he gets away with it, then I'll do it too." This habit of track limit violations must stop. Plain and simple: a track is a track and its limits are limits. If a driver fails to adapt his speed in negotiating a turn for no justifiable reason, strip him of that speed gain advantage by imposing a penalty. That will make him think twice next time around. A gravel trap right next to the curbs, and you won't see this kind of abuse again (Bahrain Grand Prix of March 28, 2021 - Race win and no penalty):
07-13-2022, 06:15 AM | #371 | |
Rep 24,863
BINO said : The Maranello's research team found that the PU from Sainz failed by the same failure as Charlie at Azerbaijan Baku , and the Ferrari PU is completely lost ! That's why Sainz gets a grid penalty at the France GP . He further said :This means that the issue still isn't solved ! Personaly I think that's bad news from Maranello ..
07-13-2022, 06:27 AM | #372 | |
Rep 19,839
The big question is if they have another new design PU somewhere and reading Ferrari's statement that Artemis posted I don't think there is, with them saying the current PU wasn't completely finished 100% b/c of covid and other hold ups and it's not just one time that manual work staff at Maranello have gone on strike over pay and conditions. |
07-13-2022, 07:07 AM | #373 | |
Rep 19,839
I saw the Petronas tee shirted drunk at Spielberg jumping with joy as Lec overtook Max. |
07-13-2022, 07:11 AM | #374 | |
Moderator
29694
Rep 13,139
Same goes for weight reduction: make the engine less 'robust' and it may fail.
