View Poll Results: What Rod bearing did you use or going to use?
Original Genuine BMW Rod Bearings 8 29.63%
WPC Treated Genuine BMW Rod Bearings 13 48.15%
VAC Performance Coated Rod Bearing 4 14.81%
Other 2 7.41%
Voters: 27. You may not vote on this poll
      02-03-2020, 08:39 PM   #1
Cyclops
Cyclops's Avatar
Which Rod Bearing did you use?
So going to be doing the rod bearing in the coupe next month and wondered which bearing you guys used. I was planning to do the WPC treated bearings but my mechanic recommended the VAC Coated. Looks like the VAC kit is $480 with the ARP bolts and the WPC kit with ARP bolts is $600. I started to read about the difference between the 2 and honestly I'm more confused now than before. I know it comes down to opinion so what yours?
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter
      02-04-2020, 06:20 AM   #2
///Mcoupe
Drives: 2007 M Coupe
I need to know as well. I read alot too and it looks like the VAC bearings are pretty tough as some supercharged cars showing no wear at all after 20-30k km. They are also the best value but whats an extra 100-200$ for peace of mind if other bearings are better...
I hope others share their experiences
      02-04-2020, 08:40 AM   #3
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Not to complicate the matter further.....
I have not done mine yet FWIW, but I know a lot of the local car club guys with e46 and e92 M3s have replaced theirs with BE bearings. However, a not insignificant number of them also swear by the OEM ones since a) aftermarket ones provide a false sense of security and b) you keep tabs on your oil reports with OEM bearings, and are more likely to catch an issue.
An opinion on which bearing to use is like an asshole. Everyone has one! haha
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      02-04-2020, 09:51 AM   #4
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
"Tough" is the last thing I want on my bearings. Bearings need to be softer than the crank journals in order to function properly as the sacrificial component. Else, you'll just be wearing away your expensive crankshaft!
My vote is OE or WPC treated OE bearings. I'm against any added coatings as those will reduce the clearance on the already tight tolerance that is on our engine. The other issue I have with VAC or other coated bearings is the material used - what is it? You'll probably lose the use of oil analysis to look for wear because you don't know what to look for - it will probably no longer be lead!
OP, if cost is an issue, ACL is a good alternative to OE => https://store.langracing.com/acl-rod...mw-e46-m3-s54/
      02-04-2020, 07:06 PM   #5
JimBob0047
Drives: 2006 Z4MR
WPC treated OEM bearings and OEM bolts. Do the vac oil pump sprocket, 034 Motorsport motor mounts and updated motor mount arm bolts while your in there.
      02-06-2020, 09:21 AM   #6
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
I can’t remember off the top of my head what I bought, but I’m not convinced it matters so much. I’ve accepted that these are basically a wear item, and will need to come out before too long anyway just out of prudence. The state of my OE’s was terrifying lol
      02-06-2020, 09:25 AM   #7
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
When did folks do this? I am approaching 84K miles and the car is tracked 3-4 days a year, budgeting for a VANOS and rod bearing overhaul soon...
      02-06-2020, 11:46 AM   #8
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
I have come to the same conclusion and just accept the nature of this motor.
Here's what my non-tracked car looked like at ~55k => https://www.zpost.com/forums/showthr...ht=rod+bearing
      02-06-2020, 05:03 PM   #9
JimBob0047
Drives: 2006 Z4MR
Here are mine with 58k grandpa miles
https://www.bimmerpost.com/forums/sh...php?p=24477227
      02-06-2020, 09:59 PM   #10
mziggy16
Drives: '07 Z4MC, '01 911 C4 Cabriolet
And mine at 120+k. Lots of easy highway miles by the previous owner.
I’m in the WPC camp based on my Indy tech’s reco.
https://www.zpost.com/forums/showpos...6&postcount=11
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i
      02-07-2020, 10:50 AM   #11
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Heh I happen to have this handy right now as I keep it at my work desk as an ornament. I believe I was a bit over 80k at the time. Sleep well
      02-07-2020, 11:30 AM   #12
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Looks like it is time to start sending Blackstone Labs samples at oil changes...
      02-07-2020, 11:53 AM   #13
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
If you have no prior history or oil analysis data, doing one right now won't be much of help. If you read my thread, you will understand why. At your mileage and usage, I would just bite the bullet and change the bearings. Otherwise, you're just pressing your luck at this point - IMHO.
86Zed932.00
      02-07-2020, 12:07 PM   #14
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Certainly digging through that thread (and this one) and amassing all information I can.
Truth be told the pictured painted online and what I hear from race/performance shops surveying 100's of S54 engine cars could not be more different. Outfits and people I trust are less inclined to jump way out front of this issue with preventative maintenance at low miles. As my mileage increases my comfort is certainly wearing thinner and thinner.
      02-20-2020, 03:35 PM   #15
Intentional Brown Stain
Intentional Brown Stain's Avatar
20
Drives: E86 Z4 MC
I am going to go with BE or WPC because these have copper core so Blackstone can pick up the issue more accurately. I believe BE bearing was designed for s65 and s85 to fix the bearing clearance issue. Some people pointed out the bearing issue on the S54 isn't its tight clearance but its small size. So regardless of what bearings we use, the only surefire way is either mod the crank and use big bearings, or keep and eye out and replace them every now and then. I am going with the latter.
I am planning to use the ecs be rod bearing kit or the ecs wpc rod bearing kit. The oil filter looks shitty. I need to look into it.
      12-12-2020, 10:49 PM   #16
rsuhandy
rsuhandy's Avatar
Drives: F06 M6;E92 M3;E85 Z4M; 958 SEH
Had mine replaced by Malek at MRF.
Mileage was just under 50K.
      12-13-2020, 10:01 AM   #17
shimmy09
Drives: 2008 BMW Z4M Coupe, 2011 BMW E
I got mine done using BE bearings with ARP bolts
      12-13-2020, 10:55 AM   #18
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Those look pretty bad for 50K miles. What year is your car? I'm starting to conclude that the latter years are worst with bearings, which is the opposite of my original assumption - perhaps laxing on the assembly specs in the latter years of productions?
      12-13-2020, 10:57 AM   #19
rsuhandy
rsuhandy's Avatar
2006 M Roadster
      12-14-2020, 10:53 AM   #20
1stw0rldpr0blems
Drives: 2006 Z4MC
I went with WPC treated bearings. These are my original bearings after being replaced with 140k miles on them, I've seen worse with less miles on them.
I also don't think there's enough data out there to conclude which option is better than the other. Is anyone on their 3rd set of bearings to see what the 2nd set looked like after x amount of miles?
      12-14-2020, 12:11 PM   #21
W///
W///'s Avatar
7494
Drives: F82GTS, E36/E92M3, Z4M
Went with OEM everything. Saw a few threads were guys have tried aftermarket, and it still showed "some" wear second time around.
I've just accepted that this is going to be an item I keep replacing throughout the lifetime of the car. Luckily, I don't drive the car that often it's OK.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      12-14-2020, 07:47 PM   #22
lauz
Drives: bmw z4m
Oem. Z4m coupe - 55000 km. Replaced with oem. Lots of city stop and go.
