07-23-2018, 01:39 AM | #2 |
701
Rep 7,850
Recaro Profi SPG. It will brush the door card with the widest point though as will most seats. It's a tight fit. You can use the size specs from the regular (not XL) SPG to compare fitment.
I strongly suggest spending a lot of time in the seat you're planning to buy. I find the Recaro comfortable even after 3 hours on the road. Not the case with some others. |
tikamak58.00 |
07-23-2018, 07:48 AM | #3 |
Monkey Marshall
621
Rep 218
Driver seat side bolster foam has separated from the frame. I'm getting zero support on my left side. I need to find a suitable replacement that will support me at all times.
I would say well I'll get some sport seats and call it a day, but finding even one that isn't >$500 is difficult. Plus I've read reviews about it not being supportive. Not that I'm tracking the car so I suppose it could work. But again the price. |
08-01-2018, 08:56 PM | #4 | |
701
Rep 7,850
Vanne1593.00 |
08-08-2018, 08:02 AM | #6 |
Rep 431
At the $500 price point, your choices for a quality adjustable seat are a bit limited.
If you absolutely want to go aftermarket, then my suggestion would be to troll CL, eBay and various forums for a nice set of Sparco R100 or R333 seats (see pricing below). You can also go with other OEM seats like those from either an: - E46 M3: https://z4-forum.com/forum/viewtopic...ilit=E46+seats - Honda S2K: https://z4-forum.com/forum/viewtopic.php?t=72750 - R100 $330 each New: https://www.sparcousa.com/r100 - R100 ~$500 set Used: https://cnj.craigslist.org/pts/d/spa...655452608.html - R333 $525 each New: https://www.sparcoracing.com/r333 - OEM E46 M3 ~$250-$700 set Used: https://www.panjo.com/buy/e46-m3-hea...l-seats-367411 - OEM Honda S2K ~$400-700 set Used: https://longisland.craigslist.org/pt...663928580.html
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo Last edited by Azeka1; 08-08-2018 at 09:04 AM.. |
09-07-2018, 12:41 AM | #8 |
Down Under!!
1593
Rep 4,293
check out Tillett seats, not a cheap option though, but you won't slide around.
https://www.tillett.co.uk/shop/shopD...r+Racing+Seats Also as Finn said, Ian's seats turned out AWESOME!! Lol, just read your sub 500 dollar mark, forget my recommendation.
Powered by Last edited by Vanne; 09-07-2018 at 12:53 AM.. |
09-07-2018, 01:25 PM | #9 |
Rep 98
09-07-2018, 01:31 PM | #10 |
Monkey Marshall
621
Rep 218
I'm actually going to go the S2K route. I don't need electric or heated seats (Florida). I am going to have to find a set in good condition, fab some mounts like the guy in the UK did and call it good. Well I'll have to uncode the seat sensors.
09-07-2018, 10:38 PM | #11 | |
Rep 98
I'll be honest that I am not sure why you would go to the trouble of trying to retro fit them into a Z4. I owned a 2007 Honda S2000 which was an AP2 model. While it was a very fun car, it was not at all comfortable. While the seats have better bolstering than the standard Z4 seats, they are not comfortable after much time in the car. They lack sufficient lumbar support and basic padding. I would recommend that you find someone local with an S2000 and go for a long ride with them before going to all the trouble. Good luck. |
09-08-2018, 07:51 AM | #12 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
I had Recaro PP’s in my previous Z4:
09-08-2018, 12:19 PM | #13 |
instagram : https://www.instagram.com/markos_z4/
64
Rep 71
this what i really like BRAUM RACING SEATS !
$800 / $900 a pair https://www.braumracing.com/universal-racing-seats/
follow me on instagram:www.instagram.com/markos_z4/
09-09-2018, 12:35 AM | #14 |
Down Under!!
1593
Rep 4,293
Id say invest in some proper seats/mounts, they ARE a safety device after all. If you cant do that, fix your OEM ones. That will be much cheaper in the long run. Seats are one cost, the mounting hardware is another. And then you have to code out the airbag light as the pax sensor/Pre tensioners wont be there. Do it properly, or don't do it at all.
Powered by |
09-16-2018, 09:33 AM | #16 |
Down Under!!
1593
Rep 4,293
Custom seats made by Steve Tillett.
Powered by Last edited by Vanne; 09-16-2018 at 09:42 AM.. |
