      09-14-2020, 01:43 PM   #1
E92William
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
USD 320.00
This 3 stage manifold is ready to install. Fully refreshed, cleaned and tested. Waiting to find an N52 as it's new home
I take apart the disa valve flaps and clean them, test the internals, grease them and put them back together and test how they work thoroughly to make sure they're in good working shape, most valves straight out of a used car will be faulty or slow so this is a huge plus to this manifold. Also these disas are both updated revision valves with no risk at all of anything dropping into the intake.
On a fully stock Z4 3.0i N52 you can expect +30hp and +10lb ft of torque with even more gains in the mid range aswell.
Videos of valves working:
Large disa
Small disa
I don't include shipping but depending where you live we can work something out
http://rover.ebay.com/rover/1/711-53...8;toolid=11111
      03-11-2022, 11:01 PM   #2
domkotlow
Drives: BMW Z4
What is shipping cost? Is this from a manual/automatic. I understand there are differences. Do you know if it's a bolt-on upgrade, I have a manual 3.0. Does it have all the required parts for it to work properly?
Thanks
