      07-28-2019, 11:13 AM   #1
2282
Ultimate Enthusiast Owner's Guide - Help Needed
As the years have gone by, Zpost has amassed tons of great info but I've found it increasingly more difficult to find that "great thread on A from X years ago." Search function gets the job done, but I think it'd be great if we had a consolidated *sticky* that contained links to preventive maintenance items, common repair DIYs, known failure items, etc... basically the ultimate Z4 Enthusiast Owner's Library
Ideally the thread could include:
  1. Official factory maintenance schedules for all E85/E86 models
  2. Suggested lifetime or preventive maintenance schedules
  3. List of common failures or known weak points
  4. List of BMW approved oils and aftermarket substitutes (including "lifetime" fluids)
The focus however is more about maintenance and less about mods. I'm happy to take a stab but would rely on folks here to send/review the info. Again, not looking to recreate the wheel (and write up new DIYs) but simply have a single source of pre-existing information, links and attachments.
v3.2mc94.00
Rekla105.00
ZMCoupe35.50
XMetal1132.50
      07-28-2019, 11:14 AM   #2
2282
*Work-in-Progress* - to be updated regularly
Owners Manual & Maintenance Related
  • Owners Manuals for 2004-08 models (attached)
  • Mike Miller's Maintenance Schedule v3.13 (attached)
  • mziggy16 's Maintenance Schedule Spreadsheet - link
  • Service and Warranty Book Search - link
Pelican Parts Repair Guides for 2003-08 Z4:
Approved Fluids
BMW LL-01 Approved - Jan 2008 (attached)
File Type: pdf Lifetime Maintenance Schedule v03.13.pdf (617.0 KB, 1954 views)
      07-28-2019, 11:18 AM   #3
2282
1. Soft Top Care
  • Soft Top removal (attached)
  • Hydraulic pump replacement
2. Audio & Electronics
  • Bluetooth retrofit (attached)
3. Suspension & Alignment
  • Factory alignment specs (attached)
4. Braking
5. Interior & Lighting
  • Adjusting headlights
  • Replacing various bulbs
      07-28-2019, 02:05 PM   #4
GyroF-16
GyroF-16's Avatar
15
Drives: Z4 M Coupe
Excellent idea!
      07-28-2019, 02:22 PM   #5
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Great idea. I'll give it some thought and offer up a few suggested threads.
      07-29-2019, 09:45 AM   #6
mziggy16
Drives: '07 Z4MC, '01 911 C4 Cabriolet
When I bought my Z I beg/borrowed/stole from around the forums and created (or maybe I borrowed & customized ) a spreadsheet that I use to track maintenance. It's mostly based on the Mike Miller guidelines and can be accessed here.
You should be able to view and copy from that link as needed. Hope it helps.
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i
      07-29-2019, 11:24 AM   #7
2282
thank you!
      07-31-2019, 04:09 PM   #8
wdb
dances with roads
wdb's Avatar
4722
+1 vote to sticky this.
      08-11-2019, 06:44 PM   #9
Finnegan
Finnegan's Avatar
Suggested topics to add, I'll add more links as search time permits.
Transmission and engine mounts. Full disclosure, one of these is mine. Link1, link2. And, why didn't I bookmark this, recently someone posted about a DIY exhaust side engine mount heat shield...
Firewall brace groan and fix (often sounds like the dash/inst cluster).
CDV delete, clutch stop
Performance pedals
Upgrade/strengthening of the from ARB mounting points
Easy peasy camber bolt addition
S54 essentials: bearings, VANOS rattle fix, exhaust hub, valve adjustment
SSK install
Weather strip replacement, other preservation steps
FCAB replacement, FC arm replacement
      08-11-2019, 07:30 PM   #10
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Originally Posted by Finnegan View Post
...And, why didn't I bookmark this, recently someone posted about a DIY exhaust side engine mount heat shield...
This one? I've been meaning to do something similar.
https://www.zpost.com/forums/showthread.php?t=1234185
I'll also try to find some links and posts for this, it's a great idea.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
Finnegan703.00
      08-11-2019, 07:55 PM   #11
Finnegan
Finnegan's Avatar
Yes!!!! That's it!
Thanks!
      08-11-2019, 11:35 PM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
I think it's still effective.
Due to my oil leak that area is such a mess I don't even want to look.
Also, the Bimmerworld mounts are such beasts compared to the VT it's probably fine.
The old girl just passed 195k miles.
Finnegan703.00
wdb4721.50
