Go Back   ZPOST > Marketplace > Sponsors Classifieds
      11-10-2018, 10:46 AM   #89
primm907
primm907's Avatar
47
Drives: Cayenne GTS
Originally Posted by Expert@ApexRaceParts View Post
Strong, light, affordable. Choose three.
Loving the looks of the ARC-8’s! Picking up a Z4MC next week.
Based upon reading through hours of fitment threads, it appears the following “should” work without rubbing...
18x9 ET30 with Hankook V12 245/35
18x10 ET25 with Hankook V12 275/35
Two things I’d like to verify if possible, though:
1) are camber plates necessary for a proper alignment on stock suspension?
2) will lowering on H&R springs potentially change the answer to #1?
Thanks in advance.
      11-12-2018, 11:42 AM   #90
Expert@ApexWheels
Expert@ApexWheels's Avatar
3555
Drives: M3
Thanks in advance.
Thank you for the kind words Primm, and congrats on the new (to you) coupe!
The 18x9 ET30 and 18x10 ET25 setup is a very popular one, and will fit without much drama in the following configuration:
Front: 18x9" ET30 with 235/40-18 tires
Rear: 18x10" ET25 with 275/35-18 tires
  • Front negative camber may be required.
  • Popular fitment.
  • 245/35-18 front tires may also be used with moderate negative camber.
In regards to your questions:
We would recommend opting for a camber plate if you intend on lowering the car at all over stock. At stock height, there will be moderate camber required (less than -1.8˚).
If you intend on fitting those H&R springs then you would need to run around -1.8˚ to -2˚ in front depending on how low you end up.
I hope this was helpful information, post up some pics of your car when you take delivery as well. I'm excited for you!
- Max
      11-14-2018, 12:43 PM   #91
Expert@ApexWheels
3555
Drives: M3
Satin Black ARC-8s on this Z4M Roadster:
We have many sizes finishes of the ARC-8's in Z fitment in stock right now.
      11-21-2018, 02:48 PM   #92
primm907
primm907's Avatar
47
Drives: Cayenne GTS
Thanks in advance.
  • Popular fitment.
- Max
Thanks. It's actually a roadster (accidentally labeled as coupe in my previous post!) with only 11k original miles. Prior owner had an ESS supercharger installed, too. 😎
I pulled the trigger on a set of Arc8's, but ended up doing 19's in anthracite. Can't wait, so hurry that order along please!!
Cayenne GTS - Daily
Macan S - Wife
Panamera Turbo S - Just Sold
M2 - Ordered
      11-28-2018, 05:58 PM   #93
Expert@ApexWheels
3555
Drives: M3
      12-08-2018, 09:01 AM   #94
primm907
primm907's Avatar
47
Drives: Cayenne GTS
Finally got my anthracite 19's on yesterday. Now to address the ride height...
Cayenne GTS - Daily
Macan S - Wife
M2 - Ordered
      01-14-2019, 05:38 PM   #95
Expert@ApexWheels
3555
Drives: M3
Looks awesome! Thanks for sharing.
      05-02-2019, 01:02 PM   #96
Residentj3553
Residentj3553's Avatar
Drives: 2008 BMW Z4M Roadster
Anyone have a picture of Anthacite on a black roadster?
      12-02-2019, 06:23 PM   #97
Expert@ApexWheels
3555
Drives: M3
Check out Josh's 2006 BMW Z4 M Coupe on 18" ARC-8 wheels!
Here is his setup:
Front:
18×8.5 ET38 ARC-8 in hyper black
15mm spacer
225/45 Bridgsetone Potenza s-04 pole positions
Rear:
18×10 ET25 ARC-8 in hyper black
255/40 Bridgsetone Potenza s-04 pole positions
