      05-24-2019, 07:17 AM   #1
kyriian
kyriian's Avatar
884
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
Rear wheel clearance for 10.5" wheel
I ran into the issue of fitting my new-to-me TE37s.
When the car was lowered off the lift, the tire and wheels were hitting the inner fender. Now the camber will be lowered but even if my tech got my camber arms as short as possible, the stock wheels/tire is already pretty damn close.
Anyone actually know the best fitting offset for anyone running 10.5" wheels?
Your help is much appreciated
Revolution of our Times
I will return to the track, one day.
      05-24-2019, 10:44 AM   #2
angelr
I've not tried a 10.5 but run a 10 at et 22. What offset are the te's?
      05-24-2019, 11:52 AM   #3
kyriian
kyriian's Avatar
884
2014 BMW X5  [0.00]
its a +30 so certainly i need to move out at least 10-12mm
      05-24-2019, 11:59 AM   #4
angelr
Yeah, that would be the way to go. Based on mine you should have clearance if you can use a spacer to move it out a bit.
      05-28-2019, 01:01 PM   #5
_christopherlee99
Drives: Z4M Coupe
I used to have TE37s 18x10.5 ET 22. Would have to lookup the camber and ride height at that time but had no clearance issues on track.
2007 Z4M built for NASA ST4
IG: _Christopherlee99
Youtube Track and Race Vids
