05-20-2020, 06:53 PM | #1 |
Rep 343
Hey guys so not a lot of reviews on these coils around for our cars so thought I'd chime in. Just had them put on today and no alignment yet. With a lot of these product reviews I think its important to get a grasp on the amount of knowledge/ experience the reviewer has so thought id clarify my perspective on the setup.
The different setups I've had over the years are KW V1s on my old b8 a4, KW clubsports and V3s on my old F80 m3, and now the PSS10s on my z4mr. I'm not a track junkie(yet lol) ive done a few HPDEs and want to start autocrossing and tracking a lot more once this pandemic is over but the point I'm trying to make is I may not be as knowledge as some other people here who know exactly how to analyze/tweak rebound compression settings in detail. That being said here's my first impression and thoughts These are only 1 way adjustable so low/high speed rebound/compression is not separately adjustable. Its all under 1 setting. Also important to note that it is VERY easily accessible at the bottom of the dampers. Adjusting all 4 takes about 1-2minutes. I started off with 6 all around(1 is softest and 10 is stiffest). Car was definitely more comfortable and smooth than stock while also greatly reducing body roll and staying flat while cornering. On factory suspension I felt the chassis was very easily unsettled by imperfections and joints in the road especially on highways. This has definitely been improved. I then went 8F and 7R and felt that this was about perfect for a street car. Not a night and day difference but felt more dialed in and car felt very neutral cornering. I then tried full stiff on 10 in front and 9 rear and while I wouldn't say it was uncomfortable id say it was unnecessary for a street car and would actually reduce traction. Comparing to my experience with KW V3s on my F80 M3 I felt like they were slightly less comfort oriented but I also had a slightly better idea of what my wheels were doing during regular driving and at the limit (even with that numb electric steering). In conclusion if comfort matters, these feel very high quality and absorb bumps well while also improving handling. That goes without even trying less that 6 clicks. Normally I wouldn't care much about comfort but I think it matters with a tiny sporty street car like this. The easy adjustability makes this a great choice in the middle of the price range for someone like me. If money were no object I think I'd go for the KWs from my previous experience, but I plan on finding an e92m3 asap and doing a lot of stuff to it so I wanted to take it easy with the z4m. For more track focused people though I think I would go with another more hardcore option. |
05-21-2020, 03:59 AM | #2 |
Όλα ρόδες
760
Rep 559
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
I had this kit installed as well last week, at the middle of the range for stiffness. I can't feel much difference to stock, although rear rebound seems more gradual/controlled.
Having said that, keep in mind that this car is very sensitive to alignment settings. Even though I feel the suspension working better, without it being too firm, the DSC light flashes alot because this time around I opted for -1,75 rear camber. It seems that is too little. I think I am going back to -2 soon since the car never suffered uneven tire wear. Up front keep caster angle over 6 with -2,75 camber. If you don't have camber plates turner used to sell a shim kit for the e36 that fits the e85/86 in order to increase front camber. I think it retailed for $35. The reason I am writing this is because you mentioned roll. You won't have any roll if you set it up as described and won't need to stiffen further. |
05-21-2020, 09:45 AM | #3 | |
Rep 343
05-21-2020, 01:11 PM | #4 |
Rep 382
Running PSS10s paired with Vorshlag spring perches and camber plates, Rouge Engineering street rear reveres shock mounts and Turner Motorsports sealed monoball rear trailing arm bushings. I have it set to 4/5 F/R. The handling is insane and rides much better than stock. It's when you're accelerating mid corner that the suspension really shines, smooths out the road imperfections and keeps the tires planted.
05-25-2020, 09:50 AM | #5 |
Rep 427
I know KW V1 are not dampening/rebound adjustable and suspension is very chassis dependent but if you did have to make a comparison how would you compare V1 to PSS10 overall?
05-25-2020, 11:09 AM | #6 |
Rep 343
To be honest the V1s were years ago but if I remember correctly they felt like V3s on a soft-medium setup while the Bilsteins are more like a perfected oem feeling setup. But the V1s were on an Audi b8 a4 so I'm not so sure it's a valid comparison
05-27-2020, 10:25 AM | #7 | |
Rep 2,860
07-08-2020, 07:35 AM | #8 |
Rep 110
Interesting review. I’m running stock suspension on my Z4M and noted the road imperfections and joints unsettle the car. I’ve been looking at Bilsteins but honestly I don’t want to lower the car
07-08-2020, 12:18 PM | #9 | |
Rep 343
I'm not sure if it's just in my head but after that extra 5mm of going lower I feel like I lost a bit of comfort in the ride so I'm going to lower the rebound/compression a bit I'm going to attempt to post a picture from my phone of my ride height let's see if it works. I swear I never park that close to the parking blocks lol |
07-09-2020, 05:51 AM | #10 | |
Rep 484
So, you should have no problem setting them at stock height. |
08-13-2020, 07:42 AM | #11 |
Rep 343
I just wanted to add one thing after spending a bit more time with this setup. If your goal is to be slammed and completely get rid of wheel gap (which was my goal) I'd recommend a different set of coils. While these were fine at close to stock height I lost a lot of comfort at max low in the rear and it's still not as low as I'd like it to be. I went a few clicks lower to remedy this but that introduced a noticeable difference in increased body roll. Not the end of the world but not my ideal setup. If you're looking at staying at stock height then these will do the job just fine
08-18-2020, 05:33 AM | #12 | |
Rep 57
08-18-2020, 07:33 AM | #13 |
Rep 2,665
Thanks for the review. I eventually need to replace the suspension on my car.
08-19-2020, 07:57 AM | #14 | ||
Rep 382
c41250n30.00 |
08-19-2020, 07:58 AM | #15 | |||
Rep 57
