      04-27-2020, 02:42 PM   #1
elerner61
elerner61's Avatar
105
Drives: '07 Z4M Roadster
Alignment Question
Could use some expert advice. 2007 M Roadie. I'm due for new shocks (80K) but can't see doing it until next summer. I have a more pressing need for new tires. My fronts are slightly more worn on the very inside than the rest of the tread. The rears are pretty much evenly worn. Overall, I probably have 2-3K left on them but the insides of the fronts trouble me somewhat because the rain grooves are mostly gone. I've never aligned the car since I've had it from 24K miles and it's never pulled or exhibited any tendencies that would make me want to align it.
Is inside wear on the fronts indicative of normal wear for an M? If I put on new tires should I definitely align it? I will probably put 3K miles on the car before I do the shocks next year (and would certainly do an alignment then).
I appreciate any thoughts. Thx.
      04-27-2020, 08:20 PM   #2
CTMP4me
Drives: 2008 Z4M Coupe, 2019 M2 Comp
Sounds like the difference in wear isn't drastic and car drives well. If the alignment pins on the front struts haven't been pulled, on stock suspension you aren't running more than 1 degree of negative camber, so you can rule out "too much negative camber" as the reason. It could be an issue with too much toe-in in that case, but I would just wait until you put on the new suspension.
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
